Sunder
Hi guys,
In my spare time, I'm doing a Youtube course on electronics. I'm not taking it too seriously at the moment as it's mainly for interest, rather than educating myself to design or even diagnose faulty equipment. (Though that may change).
With the basics I've learned so far, I think in theory, a high current charger should be very cheap and easy to build. From what I know (and this could be wrong):
1. Get a transformer with the right number of turns to reduce 240vac (or your local supply), to say, 48vac (or a little bit higher to account for losses in the next steps).
2. Insert a full wave rectifier, to turn it into pulsing 48v DC.
3. Put a large electrolytic capacitor in parallel with the rectifier to smooth the pulsing DC into smoother DC power.
4. Put a resistor in series to lower the current to the desired level.
5. Use some diodes in series to lower the voltage to exactly the desired output.
So, my question is, would this work, and if it does, why don't they exist? Surely there is a demand for cheap but low quality power supplies. My thoughts are:
[*]The voltage would not be regulated - but charging a battery, as long as the variation wasn't big, that shouldn't be an issue.
[*]I don't know if the DC would be "dirty" (i.e. still get noise from the AC side, or nearby other electromagnetic fields), but again, as a pure battery charger, shouldn't matter.
Have I misunderstood the lessons? Any input appreciated.
