Jan-Erik-86
- Joined
- Jan 23, 2019
- Messages
- 110
Hi,
I'll soon be replacing my square wave controller (kt48zwsrl-zc21) with a sine wave controller (kt36/48svprk-sls02e), but while both are from KT and are compatible with the LCD3, they don't have the same connectors.
My current controller have battery, PAS, a 9-pin connector for the motor, and an "unknown number" (can't remember how many) multi-pin connector for the LCD3, throttle and brakes (i think, but brake switch is not in use anyway).
The new one have the stock jungle of wires and connectors that we see all the time, and so i've been able to identify almost all the connectors, but i'm still not sure if i understand how to connect it all. The PCB is marked KTE-18s5.
Take for example the cruise wire - this is something i've normally controlled by holding down one of the buttons for the LCD3, and the same goes for controlling the lights.
I plan to replace most of the current wires on the controller, and at the same time i'd like to remove whatever wires will not be in use anyway.
From what i can see the LCD3 comes with a 5-pin waterproof connector, but i can't seem to find this connector anywhere?
I'm guessing i would need an 8-pin connector between the LCD3+throttle and the controller, and 2 (or 3?) more pins if i want regen and brakes switch as well?
Could someone please explain how i wire it all up? Also, as i still have some unidentified wires on my controller, does anyone happen to have the wiring diagram for my exact model?
