leaning trike cargo bike front end kit
hodala said:
Installing the BF motor kit front light
I just found this thread.
maybe this is the same as the one on the Intructables site.
Mr. Hodala, this is very interesting.
I want to try to make a tilting trike with a mechanism like the one you made.
Of course I will adjust it with materials that are easy to get or buy around me.
Thank you in advance.
[/quote]I will adjust it with materials that are easy to get or buy around me.
[/quote]
I guess you mean the laser cut plates, it's easy to order the place I live
Wish you enjoy the leaning trike fun
I'm building an active lean trike now for aged people
By the way; I'd just finished a subject, a smaller trike than my works before,with an export trade company who'll supply product for a Japanese buyer they were said retired from PANASONIC e guys, as aged people,they want to supply aged peoples with leaning trikes for safty
As e guys they have less knowledge about mechanism,revised my design in 3rd sample trike only to failed, so I correct the wrong place to build the 4th sample
I can't post pictures for business sake
I've had my kit from Hodala installed for over a year now, and I've finally uploaded some video. I took it on a snowy road with slick tires just to demonstrate the stability. Pretty happy with it! I think with some knobby tires it could be a much safer option for riding in slippery conditions than a bike. The squeaking sound is the brake rotor dragging. The disk tab is bent due to heavy braking.:oop: If I build my own king pins next time, I'll definitely beef them up.
I think my next test will be seeing how it handles heavy loads compared to a long tail cargo bike.
Glad to see your post and know the plate in lack of rigid, I'll remodel the plate with stamping parts in mass production as shown in the picture purple ones and thicker the clamp fix plate
Went for a picnic yesterday with my new bike during 4 days local vacation
Anti-tilt lock pin & steer column lock
Yes, the handling of the trike is really quite good. Most people that have ridden it say that it very much feels like a bike.
Regarding the disk tab, I think this may require a design change to the knuckle. I think you may need some way to bridge between the front steel plate (with the disk tab) and the rear one (where the steering arm attaches). Or some more direct connection from the disk tab to where the hub axle mounts. The disk tab in the current design is kind of floating with little support.
Otherwise everything is working well. What are your thoughts on the longevity of the rod ends? Both the wear out and the loading of the rod ends in bending? Generally, rod ends are not meant to be used in areas with bending loading.
I'd ridden the bicycle front end kit for 4 years and the knuckles not found deformed yet; I know the structure is not rigid enough so the stamping model of mold already in process since the distributors of Japan for sure to purchase my design
Many type of the leaning trike also use the rod end products like the Harley and some famous bicycle trikes, most buggies knuckles use rod ends too, the function and durability will be no problem, once it worn out, its easy to buy everywhere,and it's cheap too
Some trips and camping
Very nice. What was the distance travelled for this camping expedition?
It's only 20km away from home with some winding trails
Last month camping fully loaded front plastic box was not rigid enough, and rear basket CG too high, so I replaced the former alumi basket and built the alumi pannier box, it's much better maneuverability now
Grocery shopping this morning
Note that below the item for sale on that page are a bunch of other apparently identical versions for other prices, from this same and other sellers. Guess it's easily cloned. ;)
copied from the linked page for reference in case it disappears:
SIGNAL INTERNATIONAL CO. LTD.
$395.00
10+ pieces, extra 15% off
Pair wheels with Diy reverse tilting kit for Bicycle​
DescriptionSpecificationsCustomer Reviews (1)You may also like
Description​
Report Item / Suspicious Activity
If you want a cheaper price, please tell me your shipping address
Because the price varies greatly between different addresses
note importante
Si vous rencontrez un problème car le système a refusé d'acheter cet article pour votre pays, veuillez essayer de changer le lieu de visite de votre pays.
par exemple, si vous venez de France, essayez de passer aux États-Unis
mais l'adresse de livraison réelle toujours en France.
également bienvenue à nous contacter en cas de problème, merci
This is 2023 version ,
riding more easier , because the component weight from 5.5KGS reduce to 3.8 KGS
After convert the 2 wheels bike used our tilting system
then became a reverse trike same as below picture
This is a tilting system for who would like to build the reverse trike( not a whole bike )
Please note : This item included as below list :
Pair tilting arms
Pair wheel hubs with axle ( 10mm )
Pair brake calipers
Pair fork clip
Pair Front wheels in 16"
1 * 2 in 1 shift cable
1 * centrol main holder with axle ( 10mm )
See below finished project(RV-001) by our customer :
(didn't copy/paste any of these images)
Here is the link for more choose , please click below :
https://www.aliexpress.com/item/100....store_pc_groupList.8148356.17.468b6fe7w0xcOP
lets to find funny riding after convert you 2 wheels bike to a reverse trike
really hope you can sharing your art to every rider here
Send me some of your converted photos of the trike , we will upload it for
all the common hobby of reverse trike if you accept :)
We welling to hearing your idea and new concept to improve our products
even we will invest more to make some more components for convert motorcycle and cycle
About shipping method :
only way is send it by sea ( take time ) cause it is heavy item .
but we can delivery order by air if you accept to pay extra cost .
Please feel free to contact us if any questions
we also waiting some one for cooperate in this business if who are interest :)
There were 3 export traders got my front end kit, they are all dishonest businessman, if someone want to be a local dealer, contact me for update kit; front end kit+bike frame will be fine
Would you mind if I moved this to the for sale section?
It's OK, thanks! retail+air freight isn't a good bargain; better cooperate with local distributors
Front loaded cargo trikes are more popular in EU,but I can't use German
How delightful to take your dog with you bicycling in the front basket view sightseeing
Under 20 kg/40 lb pets sit in the basket will be fine, the shiba inu weighs 14 kg
upper cage preventing its jumping out
The spare wheel power only need on/off switch at low speed
One button automatic expand to drive and retrieve is more attractive
English lessons
I'm building this now
