Fardriver controller problem
Albie72
⚡ Regular
Hi I have a fardriver controller worked great. Now all it does is beep when I turn the throttle. I change the throttle and the same. I tried to relearn the controller but it wont let me. Is it the controller or my hub motor
Just have a look in the App and it will show you what is wrong.
One beep according to the manual is either brake/sidestand or throttle
Ok thanks this is my second throttle I changed. I put a new one on and same thing just beeps. I looked on the app. Ut I do t want to change anything dont want to make it worse
Normaly you can see under "Graph" what is going on, the controller will tell you what is wrong.
Have you checked brake and sidestand?
The controller will show if you are in brake or parking mode or if the throttle is not around zero Volt after turning the controller on.
Here's what it says
As I have melted my phase wires, I can not have a look what mine is showing during normal operation at the moment.
The ggod thing, It is showing no error on your picture.
What happens in the Graph when you twist the throttle, does it show any voltage readings from the throttle?
What happens when you brake or use the side stand?
The voltage goes up a little.i dont have anything on the kickstand
The factory is sending me a new controller with double the amps my question is when I do the learn do I have to have it in drive or park thanks
The auto learn is done with the wheel in the air and in drive mode. In parking mode it will only beep.
They send you a new controller?
It took me over three month with a lot of mails and video call sessions with the chinese until they said the first time they think about sending me a new one. Mine was equipped with the wrong firmware , 72V instead of 96V and I could not load the new firmware with a android tablet or phone, because the app was faulty. In the end I was able to load the new firmware with an I-Phone 6.
I deal with a gentleman in China that I bought the motorcycle from I do pay for shipping. I had the motorcycle for 3 years now and any problems I have he sends me what I need. But it will take about a month to get. But I think that's what happened to it it just beeps like it's in park
It sounds just like you have the brake signal enabled.
When the brake signal is enabled the controller beeps and doesn't move the wheel.
Go in the parameter tab, then go to functions, then click on Brake, and select "disabled".
Now your motor should run fine.
Just tried same thing a beep. The red exclamation mark is on even in drive
The red exclamation mark is " brake enabled"
The controller does not show any error.
If I pull the brake and turn the throttle my controller also beeps and does nothing.
Just have a look and measure if one of your brake switches or the sidestand switch is activated.
Here it is now
