The two Ego batteries I’ve opened up had Samsung 25R cells inside — so plenty capable cells.If they're 5Ah, and 56v (is that full charge, or average voltage?), then six of them in parallel would give you 30Ah, but you'd still only have 56v.
There's no way to get 80v out of them, without disassembling them and building a new pack with a different series cell configuration.
I dont' know what currents they're capable of, but it's probably more than 2C, so you could probably supply at least 60A with a 6p pack setup of those 56v units. That gives more than 3kw capability at 56v.
Whether or not 3kw will do what you want, you'd have to either test, or simulate, or calculate.
The ebikes.ca motor simulator has custom fields for almost everything, so for instance if you know the rolling resistance of your tires, you can add them up to simulate that in two wheels, you can guess or test the Cd/etc for wind resistance, and you can enter the total weight you expect, etc. (you can also setup custom motors and controllers, as well as gearing for non-hubmotors)
Thanks. By used EV modules you mean from a wrecked LEAF or similar? Can they be taken apart and reconfigured you mean?The two Ego batteries I’ve opened up had Samsung 25R cells inside — so plenty capable cells.
But it would strike me that learning how to build a battery from used EV modules or paying someone for their help in this regard may actually be the easier route when compared to running an ATV off of a half a dozen lawn mower batteries.
Or keep an eye on sites like batteryhookup to see if they sell off already broken down cells for reuse.Thanks. By used EV modules you mean from a wrecked LEAF or similar? Can they be taken apart and reconfigured you mean?
I haven't done and ATV before, but I'm pretty sure you should be thinking about 1 large/capable motor for the rear differential, and leave the front wheels alone for just steering.I wondered if it would be possible to use two motors and two batteries, or one battery to two motors, one for the front wheels and one for the rear wheels?
Google Dunning-Kruger effect while you are at it.I dont understand current at all, so more googling for me today![]()
How easy this is depends on the battery and BMS design in them.Thank you for that. I noticed there are battery connectors on bikes.ca site that allow two 36V batteries to be connected in a series to produce 72Vs. Maybe an EGO battery adapter could be built or modified to connect 2 or 3 in series and the rest in parallel?
Im afraid my lack of experience is showing. Looking at the inside of the front and rear wheels I cant tell where or how the hub motors would mount? I see what looks to be brakes on both sets of wheel. Would the motors just screw on to the lugs where the existing wheels are now, and all else remain the same? In other words, would the hub motors just replace the existing wheels?But you could certainly replace all the wheels with hubmotors, there are plenty of motors around with single-ended axles or other mounting solutions. QSmotors has several on their site (or see their sale thread in that part of the forum, and Goldenmotor also makes some, as do other companies (UUmotor? can't recall the names for sure).
for this type of mounting usually they replace teh whole wheel mount / drum, and the wheel hubs then bolt to the motors just like they used to the original mounts. that way you don't ahve to pull hte motor off to change the tire, just the wheel like normal.Im afraid my lack of experience is showing. Looking at the inside of the front and rear wheels I cant tell where or how the hub motors would mount? I see what looks to be brakes on both sets of wheel. Would the motors just screw on to the lugs where the existing wheels are now, and all else remain the same? In other words, would the hub motors just replace the existing wheels?
I did just that. So good advice!you should rpobably check with qsmotors about a central motor drive that would mate with your transmissin/transaxle/wahtever it is.
depending on the input shaft design ou might have to make an adapter plate that includes bearings, or just a splined connector between motor shaft and input shaft.
Thank-you. Im going with the mid-drive as suggested. Thats what I needed to know about hubs - they only seemed simple. Still trying to figure out where a good source for the battery might be. Any suggestions?I think it's wise to steer clear of hub motors, a conversion with hubs is at least twice as expensive. Not to mention all the additional fabrication to get the brakes working again.
Batteryhookup.comThank-you. Im going with the mid-drive as suggested. Thats what I needed to know about hubs - they only seemed simple. Still trying to figure out where a good source for the battery might be. Any suggestions?
Joe
A couple of these in series would get you 72v nominal 84v max, already in a case and wired.
Specs claim ~14amps per cell continuous X 11p = ~154amps.
If you needed more power you could get 4 modules and series/parallel them.
If you pushed them hard, 2 modules in series, 72v X 154a = 11,088watts. ~48lbs of batteries, 3.96kWh.
Conservatively, if you had 4 modules, ran them at 200amps max, 72v X 200a = 14,400watts ~96lbs of batteries, 7.92kWh.
110 2170 M50LT 3.6v 5000mah 36v 1.98kWh - $88/kWh
Note, I have an affiliate account with them, if you use the link above, you get a 5% discount off your order.
You will be sorely disappointed with your finished product. 100%. You are so deep into this without getting the basics right first.I feel like 30 miles range would probably be enough, although 40 is probably better.
Your ATV had something like a 30HP gas engine. Your proposed electric drivetrain is not even close.
What would you suggest would get it closer?
