nickceouk
🔋 Established
- Joined
- Jan 18, 2020
- Messages
- 86
So far I have a rear hub wired to a Baserunner v5 z9 headless (no cycle analyst).
The thumb throttle and ebrake are working and behave as expected.
The bike has a 3 wire cadence sensor and I have connected the 12v(sometimes shown as 5v) of the BR Pas cable to the red wire of the cadence sensor, the black cadence wire to Gnd of PAS BR cable and green cadence sensor wire to PAS 1 pin on the BR Pas cable.
I tried pedaling the bike upsidedown and it's not triggering the pedal assist.
In the Phaserunner windows software, the pas is lit solid green when not pedaling but starts to turn off and on if pedaling at modest rates.
Also the cadence sensor on the bike has a led at the base of the pedals. This led blinks green about 12 times per pedal revolution.
On the software I have exposed the hidden by default PAS Setup tab(File->Advanced->Show Pas tab.
On that tab I then changed Pedal speed sensor pulses per revolution to what I counted as 12 blinks. Is this how this is set?
Finally "Cobtrol Command source" was set to "Throttle" which I changed to "Throttle or pedal assist" and pressed saved parameters.
Unfortunately even though the throttle works fine the PAS does not work.
What could be the reason? How do I get it working?
