nickceouk
🔋 Established
- Joined
- Jan 18, 2020
- Messages
- 86
I need to operate my ebike taillight with the same 2 wire (NO) ebrake that is wired to the controller Baserunner.
The taillight is powered with battery voltage and individual switch with turnlights which is great for a headless setup like mine.
The problem is that I need to operate both the taillight stop light when the lever is pressed and the motor braking.
The taillight has a harness and two of the connectors are for the 2 brakes. I checked the voltage against ground and it was 40V.
On the controller side the voltage is 0.85V which also gets pulled to Gnd when pressed.
I can alternate to connect the lever to either control the motor(grounding the 0.85V) or the taillight (grounding the 40V) but can not get it to do both.
I should mention that because of how things need to be set for this controller the ebrake is returning signal to the same line that the throttle does ( Baserunner headless, dictated this arrangement) when wired to stop the motor.
Any clues?
Any clues?
