The Toecutter
- Joined
- Feb 8, 2015
- Messages
- 1,466
I have two light vehicles right now, an unmotorized Milan SL velomobile, and a custom-built electric velomobile on a KMX frame. There has been a small number of times where both were out of commission for brief periods, so I decided to add a third bike to my fleet.
I picked up a used Diamondback on craigslist, which will be receiving my old Phaserunner controller, 1.5kWh Li Ion pack, and Leafbike 1500W 4T motor that used to power my electric velomobile(which has since been upgraded to a 3T wind Leafbike, ASI BAC4000, and a 1.7kWh pack of Molicel P42A). I wanted dual suspension because the potholes around here suck. My expectations aren't high. I'm looking at running perhaps 2kW peak and will use 750W or so most of the time. This build will be much less ambitious than my first, and is going to serve as a back-up bike when all else fails.
I plan to make this able to cruise 25-30-ish mph, maybe top 40 mph(although it wouldn't be safe at speed), and it will probably only get a 40-50 mile range at cruising speed with a stock body.
However, I do intend to increase that range by making a mini bullet faring. See the following moped build for what I've got in mind:
This all said, it appears that my right-side front shock is missing a plastic boot. Does anyone know what they are called and where I can order a replacement? I'd like to keep the rain out.
