James340
I don't really know how it works but just installed it.Passive balance has to be left charging but active balancing? Thanks for your time
I don't mean to intrude on someone's thread but I have a question about active balancing.It does not need to be charging like passive balance? Thanks for your timeAn active balancer shouldn't do anything to interfere with the Nuc operations, since it doesn't connect to anything but the cells, and doesn't go between the pack and charger, etc. All an active balancer does is transfer charge from one cell to another, constantly, all the time it is connected, so that all cells are equal voltage. Some of them have limits below which they do nothing, some old crappy ones would keep going until all cells are dead if there's a "leak" in a cell that keeps dropping it's voltage relative to others.
A passive balancer is identical in connection, but all it does is drain any voltage on a cell that is over it's built in or programmed limit, so if no cells are over that limit, it does nothing.
Only an actual BMS that is wired up with FETs (or contactor) between pack and charger (or discharger) would interfere with the Nuc / charging, and that's something you'd have to check with Nuc to see how it responds to shutoffs.
If the Nuc charging works like an actual charger and just resumes charging after interruptions, wihtout manual intervention, then a BMS on the battery will work just like it would wtih any other charger.
I installed a Active balancing unit.Depends on the BMS or balancer design. You'd have to check it's manual for how yours works.
This is the picture of the active balancers I been using.
I have the same problem with PVC/shrink-wrap battery.I am just using it during the chargingI have a 4s active balancer on my 220ah lifepo4, I've kept them connected 24/7 for the past 3 years during charging and discharging. On my battery it goes out of balance quickly thats why I use the active balancer instead of trying to find the bad cells (160 cells total).
This is the picture of the active balancers I been using. Without the balancers one of the cells would be reading 3.60 volts and the 3 others would be reading 3.40 volts. The active balancers allow me to fully charge each cell to 3.65 volts without activating the BMS early.
Cheap BMS?These are all from AliExpressWhy does it go out of balance so quickly?
Bad cellsCheap BMS?These are all from AliExpress
