THE DM01 MOTOR: ENGINEERING EXCELLENCE FOR E-BIKES
Hello. In relation to the DM02 500w 52v, is that 500w continuous or 500w max? If continuous, what is the max current likely to be?
What gauge (amperage) power wires should I use from the battery to the controller?
What amperage fuse should I use?
Hello, thanks for your inquiry, sorry for the late response because of the Chinese New Year vacation.
Please note that our mid-drive motors are defined by a rated power, so the peak power of our 500W motor is greater than 500W. In our recommendation, the maximum current should be 20A for a 500W 36V, and 18A for a 500W 48V motor.
Typically, there is no need to insert a fuse between the battery and the controller. Because:
The battery itself has a maximum discharge limit.
The controller often includes built-in maximum current protection.
Any further questions you are welcome to reach out at any time.
Perhaps you can also answer some more details about the torque sensor itself:
1. is torque reading linear?
2. what is the maximum torque reading range?
How does Toseven's torque sensor differ in design from Tongsheng's TSDZ2? Can you give us an overview with photos and diagrams?
Happy New Year!
Happy New Year!
Happy New Year! Thanks for your inquiry; we kindly recommend you buy one of our mid-drive motors and test the difference between our DM motor and TSDZ2; thanks.
Hi Happy New years!
Are you saying you have to buy the motor to get answers about your products?
Regards
Cryingmadman
“No Risk it, No Biscuit”
Titanic Thompson
That's not even remotely a useful answer to the question:
I think y'all should hire some actual customer service and support people that can read questions and answer them usefully.
Hi Happy New years!
Regards
Cryingmadman
Titanic Thompson
Thanks for your message! You are welcome to visit our factory website: to7motor.com to have all the detailed information of our DM mid-drive motors, thanks! And we are happy to assist you with any questions or concerns at any time
No, I am not buying one anytime soon. Here is someone ToSeven DM01 Set Up Questions who bought one and having problems setting it up. Maybe you can offer him some help?
Greetings! Thank you for your update! We are happy to assist all of our customers with their issues. If you require any assistance or support from our factory, please feel free to contact us at any time. Have a wonderful weekend!
Hello, thanks for your inquiry! Please have our response as below:
1- yes, our torque is reading linear
2- the max. torque reading is 3.3v
Hello, thank you for your kind suggestion! The primary goal of our factory is to provide the best possible product to our customers. We cannot compare ourselves to other brands of motors since we can only judge our product. However, we are happy to provide any information you may need to know about our motors. Would you like us to provide a comparison between our motors and Borch? :)
In regards to our factory's service, please let me know of any service complaints about our to7motor. I believe we are the best service for this business. It's impossible for us to leave any customer's problem unsolved. Have a great weekend! :)
Ad. 1. thanks, that is promising
Ad. 2. sorry i was not precise: what weight can be read when put on the pedal? like 40kg, 60kg ? or can you provide torque reading?
Since to7motor@SZ didn't answer my questions about the torque sensor, I searched and found this image on reddit
Can someone check it for accuracy?
It says the torque sensor is a strain resistance type. Looks like it's located external to the motor, unlike the TSDZ2 which use a wild scheme hall effect torque sensor via a transformer inside the motor casing. How well the Toseven torque sensor works remains to be seen.
He seems most confused by magnet placement on the rotor by not being surface mounted. I read something about "buried" magnets as in the ToSeven design. It's that way for a purpose, but I can't remember what. Something to do with how the magnetic field works in the motor.
Hi,
id also like more information on the To7 Torque sensor. I had a TSDZ2, the torque sensor failed twice within a week, got free repalcements via PSPower. It was a good motor when it worked, feeling good with Torque sensing, but i could not trust its relaibility to assist my cargobike which i used daily for school runs and work. It ended up on my wifes leisure bike, and i switched from a hefty Dutch Cargobike to a lightweight Bullitt, still manually ridden... :)
Introducing the DM01 Mid-Drive Motor—the quintessence of e-bike ingenuity and performance. Boasting a formidable rated power of 750W – 1000W, this motor delivers a thrilling fusion of velocity and power, transforming each journey into an adrenaline-fueled adventure. A hefty torque of 160Nm launches you ahead with conviction, effortlessly surmounting inclines and accelerating with notable ease.
With an IP65 waterproof rating, the DM01 excels under any conditions, whether it’s amidst drenching rains or on sun-baked trails. Its compatibility with 48, 52, and 60-volt battery configurations allows for a smooth integration with diverse e-bike models, offering you the liberty to select the power system that aligns with your cycling preferences.
Designed with performance at its core, the motor hits a top speed of 160RPM, placing you well ahead of the competition. Built to last, it performs flawlessly in a broad temperature spectrum from -20°C to 50°C, guaranteeing dependability from icy dawns to the height of the midday heat.
The central position of the DM01 ensures perfect equilibrium and integration with the bike’s framework, enhancing the sensation of the bike being a natural extension of the rider. Advanced cadence and torque sensors provide a ride that feels instinctive, with power adjustments that are in tune with the intensity and tempo of your pedaling.
Able to accommodate chainrings from 46T to 54T, this motor is tailored to your individual riding demands, whether seeking speed or torque. Its ultra-quiet operation at under 50dB guarantees that your rides remain tranquil, letting you absorb either the tranquility of nature or the city’s ambiance.
At 5.8 to 6 kilograms, the motor’s weight reflects its robust construction while still preserving the nimbleness of the bike. The DM01 is more than just a motor—it’s the pulsating core of your e-bike adventure, propelling you with strength, precision, and intensity.
The DM01 adapts with ease, featuring a BB Axle designed to snugly fit sizes from the standard 68mm and 73mm to the expansive 100mm and 110mm, catering to a broad array of bike styles and certifying its role as the powerhouse of your riding experience.
With a Reduction Gear Ratio of 40.27:1, this motor is crafted for peerless efficiency, channeling your pedaling effort into potent motion while preserving a peaceful ride. The high gear ratio ensures a fluid start and continuous control, whether on challenging ascents or during swift rides.
The DM01’s design is as beautiful as it is functional, offering Shell Color options in Black or Silver for a customized look that can highlight or complement your bike’s appearance. These choices ensure the motor not only functions impressively but also enhances your bike’s look with a stroke of sophistication.
The DM01 is not merely a component—it’s a proclamation. It symbolizes a perfect union of power, versatility, and style—a definitive emblem of To7motor’s commitment to cycling superiority.
Whats the difference between the DM01 1000 watt and the DM01 750 watt?
