Hi all,
Half way through a steep uphill climb (on support level 5), my motor shut off and now I'm getting an Error 04 on my display [1].
I have a 2018 Surface Shred with a Bafang DP C07.UART display.
After searching around a bit, I found Bafang documentation on Error 04 (link) that suggests the issue is either a stuck throttle or a broken controller.
To see what's going on, I would like to disconnect or replace the throttle, however, it's not obvious to me how to do it as the cables seem to be fix (see picture [2]).
My question is - how do I disconnect the throttle? Do I need to open up the display? Will it not work at all (short of clipping the cable)?
Thank you!
Chris
P.S. I don't really think it's the throttle, but probably something got fried / overheated while going uphill - but want to test the simple things first before starting replacing things like controller or motor
[1]
[2]
Thank you!
Chris
[1]
[2]
