ebike4healthandfitness
- Joined
- May 19, 2012
- Messages
- 801
Assume both set-ups are equally reliable when maintained. (Leaf bike 1500w would need more pedal drive train maintenance but less motor maintenance compared to the geared hub with single speed pedal drive train)
1500w bike Leaf bike DD motor has peak efficiency of 90%.
1500w Geared hub motor has a peak efficiency of 83%.
Which one would you choose and why?
Would you want multiple rear pedal drive train gears but lower motor efficiency at low speed or would you prefer a single speed pedal drive train with higher motor efficiency at low speed?
How much is maximum tire width a factor? The single speed pedal drive will allow for a wider rear tire.
