TheBeastie
🏍️ Giga poster
I am doing a fat bike conversion and ordered a rear hub motor that was supposed to be with a standard rear axle of 12mm with 10mm flats.
I laced the motor into the rim and only after when trying to put the hub motor wheel in I noticed it didn't fit very well into the fat bikes frame dropouts, as shown in the pictures. Turns out they sent me a 14mm axle rear hub motor.
I double checked the chinese ebike website I ordered the motor from and 14mm rear hub motors isn't even an axle size they sell. So I am suspicious they had this 14mm axle sized hub motor sitting around and decided to just dump it on me.
I guess my main question is, will it work OK anyway? I guess there is a limit where it is dangerous, if I just use the LCD/controller settings at no more than something like 600watts of power will it be OK?
Here are a bunch of photos of the 14mm axle in the drop out that is meant for standard 12mm by 10mm axle.
I am pretty disappointed in the seller, I make a total $1600 AUD order and this is what I get.. I could have bought a complete electric fat bike locally for that money, it's so much cheaper than it used to be, but I thought it would be nice to build something that I wanted specifically..
I ordered some front fork 14mm front torque arm and going to try and make it work but I noticed standard front fork 14mm torque arms don't fit very well on a rear drop out, does anyone have any links to 14mm torque arms designed for the rear instead of front forks? As it doesn't seem to be a typical thing.
Thanks
Thanks
