Happy New Year all
I have a 29er steel all road, gravel bike that has been unused for several years that I’m planning to convert to a 20” cargo fork fwd hub motor.
To be completed by the fall.
The EBB and rear dropouts of this frame make a mid drive or rear hub build a challenge, other than a Grin All Axle or GMAC, without modding the frame which I don’t want to do.
I already have an rear All Axle build that is my current daily driver, grocery getter, gravel, do it all ride, in conjunction with a Burley COHO trailer.
I’d like to have a second Ebike that would become my primary daily driver, grocery getter, do it all ride.
I’ve sourced a CrMo cargo fork that look as though they would be suitable for a front hub build and would appreciate your thoughts and input about my current conversion plans.
Essentially my current plan would involve fitting a 20” hub motor and a shallow, lidded, Euro Crate to the cargo forks with the battery inside a partition within the crate and possibly fitting the Baserunner/Phaserunner controller inside or outside the crate. With additional room for waterproofs, tool roll, pump etc.
A second, deeper, Euro crate can then be mated/stacked on top of the Battery/Controller crate, held tight with a strong coupling system on both short sides. Additional couplings could be added to the long sides of the crate, if needs be, and or straps etc.
I’m aware that this could effect the handling and that the battery weight would be better behind the steering axis but I would like to keep as “clean” as possible look to the build, without a battery fitted within the triangle or a rear rack battery.
I’ve also carried much heavier loads on top of the rear rack of this bike frame,in the past, such as full 5 gal heating fuel bottles and panniers full of groceries, before purchasing my COHO trailer.
***Worst case scenario I would/could fit a downtube battery.
Cargo Fork:
The fork dropouts look, to me, as though they’re suitable to file fit either 12mm or 14mm axles and a decent size for fitting custom or store bought torque arms/plates, such as the Grin V7 and V5
The rack has plenty of threaded inserts to help securely attach the Euro crate
Fit a fender and mount a front light.
Motor:
#1 At this time, despite its weight, is a NC Grin FH212 which is easily available within the EU.
#2 Grin eZee regen, only available as an import to the EU.
*I love regen braking on my Grin AA
Controller:
*Baserunner L10 or possibly my AA Phaserunner
as I am considering using a baserunner in my EM3ev case to give my AA build a cleaner look.
*Either fitted within the Euro case or externally.
Battery:
At this time, I’m looking at an Amorge 13S4P 20AH*** because of its rectangular design, which fits within the Euro crate nicely.
9.5*10*31cm (3.75*4*12”)
ANT Bluetooth BMS
XT60 Discharge port
XT30 custom Charge port ?
which would allow me to use a XT30 to ST3 charge port that could be mounted inside the Euro crate allowing for easy external charging.
Advice needed to fit an isolating switch/on off switch that could be fitted to the back, or preferably to the underside of the Euro crate.
Sticky foam tape for extra protection within it’s dedicated partition ?
***A lower AH rectangular battery may be considered before completing the build.
Display:
CA V3
Torque sensing BB
Back peddle regen braking
Euro Crate/Battery Box:
I’m assuming that attaching sticky back foam tape to either the cargo rack rails and or the underside of the Euro crate would be advised before using screws to attach the crate to the cargo rack ?
I’m considering using L aluminum profile to create a foam limed, rear battery partition and possibly U section to create a lid to this partition.
Centering the battery and using low profile L aluminum to prevent any sideways movement, roughly creating two 10cm, 5”, pockets either side of the battery for the controller, cables, ST3 charge port mounting and externally accessible cutoff switch.
The remaining approx 31*27*10cm 12”*11*4” space can be used for waterproofs, tool roll, pump etc etc and could be partitioned to keep everything organized.
Epoxy bonding the aluminum to the plastic crate and or pop rivets ?
Summery:
If you’ve made it this far, thank you and I’m looking forward to hearing your thoughts, advice and/or suggestions about this build.
Cheers
Cargo Fork:
Motor:
Controller:
Battery:
ANT Bluetooth BMS
XT60 Discharge port
Display:
CA V3
Torque sensing BB
Summery:
Cheers
