Could be cheaper to get them from grintech.eu:
Torque Arms - Ebike Parts - Shop
I like VESCs a lot. Big fan of the spintend brand because you get a good quality VESC at a middle price that way
Thanks, Grintech is only 10€ shipping for me.
Speaking of cheaping out, i can get the Makerbase VESC 75200 200A from Aliexpress for 88€. Spinted i could only get 100A for that price, i guess it would have less thermal headroom.
Don’t ever charge that battery indoors and don’t leave it unattended. Sounds like your willing to cheap out on the most important components when to comes to safety, but don’t forget the safety of others who you may also put at risk.
Yea i am already charging this battery attended only. But not because of the battery itself, its made of high quality Samsung cells but because i replaced the locked BMS with a small chinese one that fits the housing.
If i get a VESC i will later also get a bigger battery with a Daly BMS or something. But ill try to do it as cheap as possible xD
I don’t think we need more pics, since a lot of people try cheaping out on torque arms. If you’ve seen one, you’ve seen em all.
I’m guessing since Germany has public/subsidized healthcare, it may be worth taking a chance, since theirs no out of pocket for the ER stay.
View attachment 377366 View attachment 377370
Thats scary. The first pic looks like its the ebay torque arm and it could be the same hub motor i bought. I wonder what happened there, did the screw loosen because the torque arm wasnt tight enough?
I guess you ordered something that looks like these kit. They offer an inexpensive way to get a fast ebike. The main tradeoff is weight. Too heavy for my tastes since I use my bikes for recreation. I suppose that if I were using it as an appliance to get to work, I wouldn't care,
The second is legality in your locale. I thought Germany would look at this as a "
faster "S-Pedelecs" (up to 45 km/h) are considered mopeds, mandating a driver's license, a mandatory helmet, insurance, a license plate, and use on regular roads"
With the size of the motor, it's obvious you exceed 250W. Good luck with the legal stuff. Good luck with the torque arm too. Crank the axle nuts down with a torque wrench too. WHat are people using? 35-40 nm?
Yes its this kind of kit. These motors all look the same to me. I hope they are the same quality internally too, i saw someone even used his with 5000W/80A.
This guy also made his own torque arm with a drill and angle grinder. I could do that too, just dont know how safe it would be in the end.
Any e-bike/pederlec here can have unlimited power legally, as long as its rated 250W continuous and has a 25 km/h limit. And the motor has to work only when pedaling. I can hardcode those limits in an open source STM32 ESC firmware. So at a legal assesment they cannot even say i could change the limits while riding. And off road i can use a different controller or flash the firmware.
I dont think the motor size is a problem legally, because there are commercial pederlecs with big motors too, they are just limited to 250W continuous by the controller.
But I agree this motor is very visible and a problem for police. At least its DD so it should be silent with a good controller.
I can still return it. Is there a smaller cheap DD hub motor i can also use at up to 2KW?
Very few actual frames come with precise 10mm openings, and that the frame is 7005 means it is easily damaged. That alloy is strong, but not extremely hard or resistant to point loads.
The problem is that if there is any play in the match between the axle and the dropout, you will (not might) machine the frame slot leading to failure. With a 1000w motor, this is guaranteed. If there isn't any play, you're going to have a hard time getting the wheel in and out of the frame to change the tires, and you'll wear the distance wider just by doing this.
The Dahon is a nice frame - what you paid for it does not change this. People are telling you to use the v7 clamping torque arm to save you money - the price of buying another Dahon-level quality frame. There is no quick-fix, and no work-around.
Im glad no one has said anything against the frame yet.
Lets say i buy 2 V7 torque arms, what speed and Watts would you trust the frame to support?
Is it any worse than a modern Cube hardtrail MTB frame for example?
