ebike4healthandfitness
- Joined
- May 19, 2012
- Messages
- 1,283
I'll verify next time I have the motor off, but fairly certain it's a bog-standard HG Spline M at 35mm. It has an HG31 8speed 11-34t on it, and don't recall having to use any spacers on it.
If you can fit an 8 speed cassette.....then it has the 35mm freehub body.
For people who want to pedal their bikes (using light motor assistance to extend range) having up to 12 gears will definitely help.
The Leaf Bike 35mm is quite efficient at part throttle. Example below using 6T winding and 22.5" diameter tires:
Motor Simulator - Tools
Our ebike motor simulator allows you to easily simulate the different performance characteristics of different ebike setups - with a wide selection of hub motors modeled, and the ability to add custom batteries and controllers and set a wide variety of vehicle parameters you'll be able to see...
However, some people don't do well bio-mechanically with the wide q factor that comes with having the 170mm rear spacing.
Unfortunately, the 137mm 35mm motor only offers 7 speed cassette. For me this would not be enough gear selection to entice me and instead I would rather choose the dish-less 35mm single speed coupled to a very small diameter (but wide) tire and take the motor efficiency gain.
Motor efficiency advantage of small diameter tire + strategically chosen single speed gear > less efficient motor (because of larger diameter tire) + 7 speed pedal gears.
But this 170mm also allows the motor efficiency of the small diameter tire but then lets a person have more gears. The downside, of course, is wider q factor than the single speed.
