2-3 kW motor and controller choice
yabert
Regular
I'm looking for a 2-3 kW motor (around 5kW peak) for converting an outboard motor for a small boat (dinghy).
48V battery.
I've found Golden motor 3 kW with EZkontrol EZ-A48400 and QS motor with FarDriver or Votol controller.
Both choice at around 1k$ or less.
Is there other choice?
Is there reasons to prefer QS over GM? Or FaDriver over Votol?
Thanks
48V battery.
Thanks
Where are you located? On the offchance it might work for you. I still have a couple of these scrapyard pump motors, one of which I used for my moped conversion. Post #62 has a pic of estimated specs. You're welcome to one.
Interesting small motor. I'm near Montreal, Canada.
What kind of controller do you suggest for this motor?
I have it running off the cheapest 3000w controller I could find on aliexpress. It's BLDC with halls, so you could probably get it running with most any controller
Might want to consider this, if you can get one:
5kW Grin Marine Motor, 20 rpm/V
Controllers? i don't have experience with this kind of application, but i like VESCs a lot because they're open source and the software that runs it is highly refined.
I realized that I can use my ASI BAC2000 I have in hand for this project.
I'm still open to suggestion for motor.
The 3KW Golden motor is a beast. Great motor for the dollar. The motor is an axial motor style and is available with water cooling, so it seems like a good fit.
