chasthanhburns
Can i charge my 48v battery with a 24v charger by only charging half the battery allowing the bms to balance the two sides?
Does it matter that i meant charge a 48v with a 24 volt charger?Sorry, thats not possible.
I think you need to clarify what you mean by charging with a 24v charger. One read is that you’re plugging in a 24v charger into the 48v battery charge port. The other is that you are opening the battery and connecting half the parallel groups at a time, but since a 48v pack is 13 groups in series, there’s no way to isolate “half” the pack. A 24v pack has 8 parallel groups in series.Can i charge my 48v battery with a 24v charger by only charging half the battery allowing the bms to balance the two sides?
You're not wrong at all. With lithium, you really have to do things by the book.I've heard that messing with battery charging can be dangerous. Have you considered getting a proper 48v charger instead? Might be worth the investment for safety reasons, but I could be wrong.
Sadly 24v = 8S and 48v is 13S, there’s no way to split the pack. The OP should not do anything until he gets the correct charger. From a safety perspective, the original question should set off enough alarm bells to avoid suggesting otherwise. He’s certainly not in a position to safely implement any creative solutions. With a lot of work and what he has to work with, the pack could be fully disassemble to the cell level, built into two 8S packs and run them in series at 16S/60V with a few cells left over. But he lacks the knowledge, and likely the tools, to do that safely.You can charge your 48v battery with a proper 24v charger by splitting your pack electrically in two (as far as charging is concerned.)
Oh no. Wish I had rad this reply earlier. My house is burning down. Wait thats just my joint.Sadly 24v = 8S and 48v is 13S, there’s no way to split the pack. The OP should not do anything until he gets the correct charger. From a safety perspective, the original question should set off enough alarm bells to avoid suggesting otherwise. He’s certainly not in a position to safely implement any creative solutions. With a lot of work and what he has to work with, the pack could be fully disassemble to the cell level, built into two 8S packs and run them in series at 16S/60V with a few cells left over. But he lacks the knowledge, and likely the tools, to do that safely.
Already tried it today. I completely disconnected my bms as i was not sure it would balance out the battery pack. I am just charging one bank then the other bank. Just needed to solder on one wire. I probably should just buy the charger but I am hard headed, i like to learn by experimenting, and aint got no money. I also aint sure of what the finish line is or what I am trying to build. It is actually a 72v battery i built. The 48v question was just because i thought it would be more relatable to those that read this. I also got a 96v controller and a108v controller I may want to use but i can not find a way to activate the abs on them and these bikes i am using are really garbage with really garbage brakes and rust and just dangerous flimsy metal. I got it up to 41 mph today when i tested it to drain the battery. 2100watts at peak with 31 amps peak. Only got 11.5 miles before the 62v cut off i set in the BMS. It almost seemed fast enough to keep up with traffic but also was scary on this crap bike. Sorta hopping for 55mph but agian the 96v controller has no abs and it was fairly scary at 41mph.You can charge your 48v battery with a proper 24v charger by splitting your pack electrically in two (as far as charging is concerned.) No bms, so be careful.
The amount of time and effort to do it makes the price of a 48v charger quite the bargain.
I used 48v as an example cuz i thought it would be more relatable to the reader but you are right. It is a li ion battery but my actual battery is a 72v battery. so 20s. I did do it. It does work. I disconnect the bms and the bike before charging the packs one at a time. I plan to check that voltages are really close before connecting them back to the bike and bms. I should just buy a charger but I bought all this stuff when Trump was handing out money. I aint got no money under bidden so gotta do what i gotta do.I assume this is an Li-ion,
In addition, a 48V Li-ion pack is built with 13 series groups which total 54.6V. It cannot be divided in half evenly, so the 7th group in the middle is a problem. You need a 29.4V charger to do the first seven groups, and a 25.2V charger to do the last six, and you still have the overcharge risk.
I should just buy a charger but I bought all this stuff when Trump was handing out money. I aint got no money under bidden so gotta do what i gotta do. Safety aint a big concern when riding something like this. No front brakes at all, front wheel i jammed in so tight that the front shocks are bond up and do notwork, no gears at all, and rust and zip ties holding it together.I've heard that messing with battery charging can be dangerous. Have you considered getting a proper 48v charger instead? Might be worth the investment for safety reasons, but I could be wrong.
You could do that with a 52V battery (14S), but not a 48V (13S), using a 24V (7S) charger (I misspoke earlier, 24V is 7S not 8S).I mean....so, it's a STRONGLY bad idea, but, yeah, actually you can charge a 48v battery with a 24v charger. You, though, would have to charge each half of the pack, one side at a time.
Yeah, ooops. I mean, I guess you still could, but...now it's an even worse idea.You could do that with a 52V battery (14S), but not a 48V (13S), using a 24V (7S) charger (I misspoke earlier, 24V is 7S not 8S).
Tried that. Cannabis caused me to plug the first in backwards now I am down to one charger. E-HP was right. I should just buy a proper charger.just get two chargers and connect them in series. If you need 20S - get two 10S / 42V chargers. Works for decent power supplies, like MeanWell, and two smaller can be cheaper than one big.
If you make a rule of no cannabis while charging, you’ll suddenly have the incentive to buy high quality, fast charging batteries. Better batteries, safer charging. Turn it into a win winTried that. Cannabis caused me to plug the first in backwards now I am down to one charger. E-HP was right. I should just buy a proper charger.
