Looks a little late now, but leaving the nickel strip on the battery when disassembling will prevent holes from being torn in them from the spot welds. Also if you must solder, the nickel strips buffer the battery from excess heat and are much easier to solder than the metal on the 18650 cans. I once read a technique for soldering these types of batteries; basically pre-tin the nickel left on the batteries. Get the fluxed pre-tinned wire good and hot before placing on pre-tinned battery surface, and immediately quench the heat with a cloth dampened with distilled water to prevent damage to the cells. This minimizes battery exposure to heat. Also using a powerful soldering iron is necessary to reduce time required to heat the wire and melt the solder. I'll see if I can find a reference to this technique, though I don't recommend soldering 18650 batteries. Too much risk of damaging the cells with heat.
