Hi there, I have had hit and miss with the ST-LINK adapters as you may have read, my ST-LINK adapter will program without any problem a bare controller, on the 48V TSDZ2B I have just reprogrammed, (1) the STVP software threw up the normal could not connect error, this happened a few times, gave up for a while as it was winter, but before I was going to pull the controller out I gave it another go with the STVP software so, (2) connected to the controller to the computer via the ST-LINK adapter with which I knew worked got same error, so unplugged the ST-LINK adapter from the computer and plugged it back in, was then able to read the parameters from the controller, changed to the Configurator was able to compile and write the new parameters, (3) now my latest updated parameters went straight on today. I do seem to get this problem with everything connected to a controller I am programing right from the first one I ever did, bare controller fine. Even thought at first I had a V2 controller until I checked it.
Not 100%, I do not think you have damaged the controller, I have switched displays on a number of TSDZ2s when setting them up without any problems, unless you have been very unlucky. Give a go with the STVP software and go from there, My ST-LINK adapter has about 140mm of cable, and I used a fully charged laptop.
