Need help with designing unique 72v battery
ElectricPuppy
Toronto, Canada
Hi everyone, I am considering building a 72v 24ah battery (20s6p), and I am curious if a segmented/separated battery would be possible.
Reason is for a unique build where space is limited, and I wanted to try and separate the battery in half while still using the same BMS.
I made a rough 3D model of the battery.
Is there any reason why this wouldn't work? My biggest concern would be the wire used to bridge the two packs together. It would be at least 10AWG and very well connected to both packs.
Please also let me know if my series/parallel connections seem OK, or if I have to re-design them. Silver is parallel connections, copper is series.
I am considering using two separate 72v 12ah packs with their own BMS systems, but I am hoping to connect them together like this to reduce voltage sag. If anyone has any experience with running dual batteries to reduce voltage sag, let me know.
Thanks!
Sure. It's been done a few times in different ways. At least one Yuba Mundo build here has a split battery, half in each of the side rails under the panniers; you can lookup the YM threads and find the details. A few other people have done split batteries for various reasons.
You might want to protect those balance wires physically, and keep them from potential electrical noise interference (using a shielded cable from the side that feeds the long wires to the BMS thats inside the other pack...or if it's separate from both, then both sets of balance wires should be shielded. It's possible this is unnecessary, but you don't want accidental shutdowns from any noise generated in the motor phase wires or any other sources that longer sense wires might pick up and tell the BMS that something is wrong in a cell when it's not.
So using a regular bundled shielded cable with a tougher outer jacket rather than the typical ribbon would be a good idea.
If you parallel BMS'd batteries, make sure you use common-port BMSes. They only have a single connection (C-) for both charge and discharge.
If you use separate-port BMSes, then you have to disconnect the charge ports while discharging, and disconnect the discharge ports while charging, or the BMS cannot protect against overdischarge or overcharge because of backfeeding thru the opposite port.
Otherwise, there's no reason to not parallel them.
As Jkreinert notes, a fuse between sections is a good idea. It needs to be higher than you'll ever use, but low enough to protect the wire it's for by blowing before the wire insulation is damaged. (it's not really there to protect the battery itself--that's what the BMS is for).
Thanks for the info! I am leaning towards doing 2 parallel cells instead (separate casings and 2 BMS), it might be easier. Do you know where to find a reliable ebike battery parallel connector / battery balancer? I have heard mixed reviews and I am not sure where I could find a good one
It is definitely easier. But remember that "cells" are what is inside the battery. What you probably mean is 2 parallel *batteries*, which is the complete assembly of cells (sometimes including a BMS, etc). Also often called a "pack" (battery pack).
Since none of them I've ever seen document what's actually inside, you can't predict their behavior under various circumstances (unless you test every possible condition and circumstance and document that, or reverse engineer it to see what it *should* do).
That makes them by nature "unreliable" since you don't know what they'll do and can't rely on them to do what you expect them to do.
None of them are balancers--a balancer is inside your BMS or inside your battery, to make each cell equal in voltage (nothing else) to all the others, usually at full charge time. Any of them they call balancers is a misuse of the term and not applicable. If they define *exactly* what they mean by that, you will at least know why and how they are misusing it...but they still aren't balancers. ;)
All of them are going to waste power, too, because there will be some form of switch or diode in there, which will have resistance and voltage drop, whcih will create heat that is just wasted power.
You can simply directly parallel your battery + and -, with a properly-built Y-cable and appropriate connectors, and have a more efficient system that performs better.
I *would* recommend a separate fuse for each battery that feeds the system, as close to the battery + or - (doesn't matter which) as possible. That way any wiring fault (short to each other, frame, whatever) can blow the fuse before the wiring insulation is damaged and a fire can ensue.
BTW, here's a couple pics you can use as an avatar if you want. ;)
Thankfully none of my dogs have ever helped me with batteries like that...though Yogi once thought a lamp cord was delicious and did have sparks shooting out of his mouth for an instant before the breaker popped and he ran away. :( (he was fine, but it probably hurt like hell and was very scary).
Cleaned up the design, other design had some sus connections. I also wired up the BMS wrong 💀 Replaced with a common-port BMS
Are there really no drawbacks connecting 2 separate batteries (with their own BMS systems) with a fused Y-cable? Can that work just as well as one big battery?
My biggest concern would be voltage sag, but I am not aware of how much sag is affected by having one big battery vs connecting 2 in parallel.
Would something like this work? (I would add fuses to all connector ends if I do go this route)
The cell block and interconnect arrangment is much better the new way; you can get lower interconnection resistance like this.
BTW, you can buy rolls or lengths of "plate' interconnect in various widths, includiing ones wiht "fused" cell connects if you want those (they also make them without that--just flat sheets, some with indents to reach down below cell holder lips, etc). Probably some nickel-plated copper ones out there too if you have a welder that can do those and need the current capability.
Batteryhookup carries some; they're avaialble lots of places you just have to make sure you're getting the real metal you're after (rather than nickel plated steel or whatever, like you find in the really cheap stuff). These greatly simplify the pack welding / construction.
There's drawbacks to pretty much any way of making and using batteries. ;)
There's more resistance in the connections, there's more connections to fail or be made wrong, etc. But there's also advantages. (see below)
FWIW, for any +/- comparison for any project, you can make a list of all the properties of each method, then for each one that's different between the methods, check which one is "better" for your specific application, and by how much (rated say, 1-10). Whichever method has more +'s with better numbers is probably the best way to do it for that application. :)
Yes. It is actually much more like one big battery than trying to use one of those battery-paralleling-devices, because there is nothing to interfere with current flow.
There will be more sag with two in parallel that are half of a bigger single pack, because there are more wires and more interconnects.
But: If you are using two BMS, one in each pack, that are identical to what you would have used for the single big pack, then there's *less* resistance to current flow in the BMS FETs themselves, as you now have twice as many in parallel, and so half the resistance.
One advantage to two separate packs is that *as long as each can fully support the system load, by itself*, you now have redundancy should a BMS fail, or a cell in a parallel group fail in a way that drains the other cells in that group.
If each pack can't support the full system load by itself, then that's not really an advantage, as it will be more likely to shutdown under load, or be damaged (or aged faster), if you have to use it by itself.
Yes.
I would simply add a bolt-on fuse in either the + or - wire on each branch of the Y. Bolt on fuses are more secure, less holder resistance (even if you use a holder vs bolting directly to the wires), if a bit less easy to change roadside than other fuse types.
Like this type; just make sure it is rated for *at least* the full charge voltage of your system (if it's not, it could continue arcing across after blowing, and cause a fire at the fuse itself from the plasma arc, rather than preventing one....).
I use this type of fuse bolted to the actual terminal of my batteries for the SB Cruiser trike, with a ring terminal crimped to the wires that go to the Anderson SB-50 connector that plugs into the trike itself. Mine are only rated for 32v, like the ones in the images above, but the datasheet linked is for a 70v version. Mine might not break the circuit (14s pack), but the 70v version would.
(I use the same batteries, two in series, for my formerly-ac-powered lawnmower, but the fuses probably wouldn't work as designed in this case; too high a voltage for them).
Whatever fuse you get, make sure it is rated per it's manufacturer spec sheet (like the one linked above) to blow in the amount of time you need it to for the current you need it to blow for, but *won't* blow for the current you need it to keep operating for. ;) There is a chart in each spec sheet (page 3? of the one linked, for instance) to let you do this.
If you get fuses with no spec sheet, you can't really know when or even if they will blow (or not blow) for a given current, or even what voltage they're good for. (regardless of the markings on the actual fuse). So stick with brand names with documentation. ;)
Yes, that's the way to do it.
Those are all hokey and unnecessary nonsense. Just connect the packs when they're both fully charged, and don't disconnect them. No need to complicate things and make your packs work harder (one at a time).
Thanks for the advice everyone!
Is this safe to do if both batteries have a common-port BMS set up?
Also, does this increase the amperage output of the batteries? or just the amp hours?
Yes.
It doesn't increase anything about either battery.
What it does is let you use two identical batteries as if they were one larger battery.
If you were using only one of those batteries, then paralleling two of them doubles both the current (amp) output, and the capacity (amp hour) but it doesn't increase anything over a single battery that was already two of those. (meaning, each of the two is 1/2 of what the bigger one would be).
Thanks for all the help, everyone! I think I will be doing a parallel battery setup with separate BMS modules, and connecting with a fused Y cable.
