EBS in Heidelberg, Germany offers the 10 Pin Higo for controllers with higher power.but I can't find any with the correct motor plug and controls connector.
Thanks for the link of a motor kit with the controller.“We hope to see this become a new industry norm” Grin
I don’t think this ever happened, and don’t see many controller manufacturers making the swap. Seems like it would need to be coordinated with motor manufacturers as well in order to be adopted.
This kit appears to use it. Maybe you can contact them to see if the controller is sold separately, and that the control cables are compatible as well.
72V2000W Electric Fat Bike Motor Wheel Kit Aluminum Rim Motor Set 20x4
72V2000W Electric Fat Bike Motor Wheel Kit Aluminum Rim motor Set 20x4.0 inch Rear Drive Ebike Motor conversion rear motor with front wheel Include Tires. Fat bike motor,72V2000W Aluminum Rim Motor Kit,Including Rear Motor wheel and Front wheel,all with 20x4.0 tires. Rear motor wheel 175mm...motowoks.com
Yea, I think I'm going to go with grin because that's the cheapest controller I see with a Higo L10 plug.EBS in Heidelberg, Germany offers the 10 Pin Higo for controllers with higher power.
But they are quite expensive and are expecting a NTC motor temperatue sensor.
EBS Next Generation Controller, 36V - 50V, mit Lichtanschluss (Akkuspannung)
EBS Next-Gen Controller 36 V bis 50 V mit Lichtkabel - rechteckige Bauform mit einseitigem Kabelaustritt - bis 90 A Phasenstrom - FOC, 6 MOS-FETs…www.ebike-solutions.com
regards
stancecoke
You could buy either an L10 extension or just the end that you need with the right length of cable on it, then isntall taht in the controller you want to use....It sucks there's no cheap 35a-40a one with an L10 on aliexpress, ebay, or amazon.
I'm not handy at all with electrical stuff and want something plug and play, so that's why I was asking.You could buy either an L10 extension or just the end that you need with the right length of cable on it, then isntall taht in the controller you want to use....
That’s just supply and demand at work. If you want plug n play enough, you’ll be willing to spend 5x more on a solution that has even more features than you need in the first place, just because it’s easy to plug in. It’s probably better to just adopt an “it’s only money” perspective, and get the bike up and running so you can enjoy it.Yea, it's very hard to find a controller with the l10 plug and I think I'll end up going with Grin.
$300 is pretty steep for just a controller but I hear good things about them and they're adjustable.
It’s not about being handy. There are tons of folks coming here for advice that have no background, skills, or tools when joining ES. But, they have a “can do” DIY attitude and are willing to learn, which goes a lot further than having a lot of technical skills or non-ebike knowledge (reminds me of a movie I watched last week, The Boy Who Harnessed the Wind).I'm not handy at all with electrical stuff and want something plug and play, so that's why I was asking.
