Ride1Up 700 Series: An upgrade journey
California
I'll try my best to convey the work I've done over the last 3 years of work on my bike. I've been writing and rewriting this for the last few weeks. I'll be honest, it's a bit hazy as to when I first added the 48V 12V dc converter, but I'm trying my best here. :)
I purchased a Ride1Up 700 Series bike in September 2021. It has the Shengyi DGW22 rear hub motor. The bike fits me well and operated just fine. This bike was on my short list. I knew nothing about what I wanted in an ebike. I hadn't ridden a bike in years and I didn't already have one. I did about 5-6 months of research before I made the purchase of this ebike. I told myself to wait until the warranty is up before I start changing things around. I only "probed" the bike and exposed the controller at the bottom of the downtube to learn what I have and what goes where. Part of the reason I went with Ride1Up was the ability to change the number of PAS levels, percent of motor power per step, and other parameters I didn't quite understand....at the time. Price was another reason, as well as their online support documents. I was able to get video instructions of most things including a wiring diagram for the controller and I could see that it was a 22a Lishui controller in the downtube. Fully potted no access to anything on the board. I also checked out the custom firmware threads. I have had custom firmware on a few game consoles, so I know I would want that. The display was a KD218. I've noticed that the settings of the PAS levels topped out at 18A. I couldn't adjust this any further. I wanted full access to the power to help with some of the 12-16% grades on my commute route.
Here was the original controller.
8 months (and lots of research) later, I got brave and replaced the thumb throttle. I hated the fact that, from a stop, I couldn't signal with my left arm and take off with the leftside thumb throttle at the same time for obvious reasons. I installed this throttle and placed it on the right side. You can see in the in the following pictures.
Next, I added lights. My bike only came with a simple running tail light. I didn't know I wanted an active brake light like on our RadRunner Plus. I found this light kit and wired it in using the headlight plug on the original controller as the 48v source. To do this I simply unplugged my existing headlight and plugged (after verifying polarity) this kit in. Wired this way, I still have to activate the 48v headlight source by holding the "+" button. No biggie, I just kept the light kit's headlight button on. I also had to follow what the product description stated "Why after connect, my brake light always on? Ans: Your brake cable is reversed, please just switch two cable of your brake lever plug". Everything worked fine after I followed that advice. Except the brake light was constantly on, so I used a 48v-12v dc converter. I fed it from the headlight plug to power the lights.
Then I got these front turn signals and spliced them in to the rear turn signal wires. I also wired in the white light by tapping into my headlight wires. This way I can turn on my headlight and these would also light up. I mounted the front turn signal lights, with these brackets, to the stanchions. Wasn't my favorite placement, but they fit. I had to lockout the fork more so the brackets don't impact the crown. Front and rear turn signals!
I later added a key switch because I didn't like the idea that anyone could just power on the bike and run the motor. Sure, there is a password feature on the stock display, but even before you input the password, the throttle can run the motor. For the key switch, I 3way spliced the ground (black) lead between the controller and display. I took the batt+ (red) from the controller and connected that to the green of the key switch. The red of the key switch went to the batt+ (red) towards the display. I moved the converter and paralleled it after the key switch, on the batt+ (the red is now a 3way splice) and ground (the ground is now a 4way splice). This worked great!
I then I added a wireless phone charger. I really didn't need this since my commute to work is only 15 minutes. I really just wanted to a reason. I was already docking my phone to the handlebars. I figured "why not charge my phone too?". So now I can flip the key and my lights and charger is active. Then I can power on the display and run the bike.
I came across some birthday money and replaced the controller and display. I first verified fitment of a new controller by cutting packaging foam to size and placing that in the cavity below the battery inside the downtube, where the original controller was. IT FIT! I ordered a 25A KT controller with the LCD8H from Aliexpress. I went with the version that has JST connectors. I fished the display cable down the downtube. There is a cavity on the high side of the downtube that all the wires feed through. Then, I had to swap the signal (green) and ground (black) wires of the throttle connection at the controller. I repinned the JST plug on the controller side so if I actually needed warranty or support, I could just reconnect the original Lishui controller easier.
I didn't realize it at the time, but those front turn signals are only rated for 12v. The right front light burnt (shorted?) out and fried the daughter board on the KT controller. Lesson learned! I desoldered the daughterboard from the motherboard and moved the lights to the run off of the converter, as well as, replacing the defective turn indicator.
I ended up replacing the motor phase wire bullet connectors with an MT60 connector. The cable exiting the motor is a Z9 plug and there was an extension cable along the chainstay and in to the downtube. I also cut about 6-8 inches off of that extension cable. I remembered reading a post around here about a guy that repairs ebikes and sees people coming in with a "rats nest" of wire in the downtube (that's where my wires are!). He stated that the phase wires would be burned up there much of the time. I wanted to get ahead of that. I noticed that my phase wires wouldn't get as hot after I shortened them and used the MT60 plug. I think one of the original bullet connectors had a weak connection. Weak connections create heat. When I stripped back the extension cable's jacket I saw the phase wires were "stressed" only at the hard bends in the phase wires (because there was too much wire stuffed in the downtube). I can just see some copper through the insulation. My motor cable is nice and straight now, with no hard bends.
Here were my settings.
You'll notice the handlebars changed from black to blue. I changed the handlebars to get more rise up front and to have a more comfortable ride. I was a bit hunched forward before, but it's quite relaxed now. I went with blue to have my bike easily identifiable if it ever got stolen. I bought this handlebar. Also got this stem since my other stem started creaking right at the adjustment bolt with no way, I could see, to fix it. Since I was increasing the rise, I also had to make a new hydraulic hose for the front brake to extend it up. I've never done this work before so it was youtube training time again for me. Came out fine, made a flush cut on the hose and the barb seated nicely, no leaks. I realized it late, but the new stem was 5mm taller. With the original spacers, I was short and couldn't fill the gap. Work stopped and ordered some blue spacers to match. That solved my issue. The handlebars were too wide so I trimmed 19mm from both sides. This brought me from 720mm width to 682mm. That was the shortest I could go. Luckily that was all I needed. My hand spacing feels much better and shoulders don't tire as easily. I used a hacksaw and a parktool-ish pipe cutter that I borrowed from my buddy. Hacksaw to the handlebar was very tiring. I used my right arm for one and my left for the other. Got to mix it up!
This all worked great....for the time. I was very happy with this set up. I think I've had like this for almost 2 years. I then started itching to see what else I could do. I have been looking at the Cycle Analyst and Baserunner set ups. Actually, I've been looking at various setups with them for some time and it all just felt out of my league. I have been on the fence about upgrading. It's expensive. Their controller is much smaller and way more configurable than the 25A KT controller I have been running.
I knew this would be a big undertaking for me to get everything configured properly. I came across @GRIN LEVEL in another thread and found out that he had the same set up I was looking to do. Actually turned out he has the same motor that I have. His bike was different, but similar components. I was pretty stoked to find all the info he had to offer. I knew, for certain, that I could get this whole system working well. Just need to be patient.
I've since now got the Cycle Analyst and Baserunner installed. I pretty much started over with this bike. Removed the 48v-12v converter, phone charger, front turn signals, even disconnected the key switch. The Baserunner plugged in right to my motor cable. I no longer needed the motor extension cable that I put the MT60 on AND I can place the Baserunner in the downtube. I have been monitoring the temp, with an external sensor glued to the side of my KT controller, in that area and I never saw higher than 50c. I wasn't sure how hot the Baserunner would get though so I bought the tube mount bracket as well. I have it on the Baserunner as a "heatsink". I'm not sure if I even need it but still, it is smaller than my KT controller so I'm still saving space. "Why not have it?". I was able to fish the Cycle Analyst WP cable done through the tray in the downtube. That plug measured 10mm in diameter and the tray was roughly 13mm. Tight fit, with all the other wire, but it worked and the cable length was just enough.
I also purchased the 24 magnet PAS from Grin and installed that. I wasn't sure if my existing 12 magnet PAS was working on 5v or 12v. Sure I could've tested to find out, but I figured 24 magnets would give me better response anyway. The cable was a bit short so I made an extension with some cat5 I had laying around and this kit. I really like JST plugs, they are super easy to work with and repin if needed. I had to swap the throttle signal and ground wires. I don't remember the reason, but I changed the plug on the CA side. The Ebrakes were backfed through the downtube, to stay connected to the rear light, then back up to the CA. I flipped the CA stem mounting bracket upside down to install the CA facing me more and staying off the handlebars and to miss the handlebar extension I have the key switch mounted to. The MP Switch went all the way to the left side of the handlebar.
I've now installed the key switch between the BaseRunner and Cycle Analyst. I've sheathed the CA WP8 cable near the head tube. There is a small cavity above the internal battery as well, and used the GRD (black) and 3way spliced the black on the key switch there. I then got the batt+ (red) from the BaseRunner and spliced that to the green of the key switch. The red on the key switch went to the batt+ (red) towards the Cycle Analyst. Now I flip the kley and the Cycle Analyst powers up.
Tuning the bike was/is the hardest part, even still, I don't think I'm done yet. I went through the auto routine and used settings that @GRIN LEVEL was generous enough to share. Thanks dude! Motor stuttering was very bad and after a few weeks or searching and reading, I found out the the issue was related to the Feedback Bandwidth Tuning. These values were not perfect for my setup. I set Current Regulator Bandwidth to 110, PLL Bandwidth set to 200, and PLL Damping to 2.8. Now the bike doesn't stutter and I take off smoothly. I also turned off sensorless start for halls only.
Here is the bike today.
Al bit more info about my riding.
I weight 160lbs. With cargo, probably 180-190lbs.
Hard to say how many miles exactly. I’ve changed from the stock system, to the KT system, and finally the Grin system. I’d guess, in the last 2 years, 2500 to 3000ish miles. I really only commute to and from work. I won’t ride if it’s raining.
All my riding is street a very narrow 3 bike lane and there are potholes. I take one paved path that leads to a wooden bridge and I rarely go over 25mph. The bridge is probably 80’ and I go about 10-15 mph there. Probably average 18-20mph along my total 3.8 mile trip from home to work. Close to 8 miles a day.
I use Tannus armor and these tubes with the stock 27.5 x 2.4 Schwable Super MotoX tires. I maintain 25psi. That was the recommended pressure. I’m trying to find where it said that. With the stock tubes, without the armor, I kept them at 50psi. The ride is dampened, but the potholes are less jarring. I avoid most of them, but I hit a few now and again.
A few things regarding the lights.
I use this to control turn signal, headlight, and horn.
The wiring key was a bit lacking. This is how I’ve wired this control to my light kit that I linked above.
The White, Orange, and Red are all connected to the same 12v coming from the DC converter.
Changed the mounting location of my front turn signals. This is better because I’m no longer worrying about my fork bottoming out and the crown getting damaged.
Thanks for all of the details, @slaphappygamer. "Throttle on the right" is how I rig my bar controls layout to free up my left arm, though I'm concerned that car drivers don't recognize that I'm hand-signaling instead of waving.
shg, good job(s) and interesting report; I've heard of some individuals making minor mods to make the bike "theirs", but yours is really "yours".
I had to adjust my PLL Bandwidth. I would occasionally goose the bike and was intermittently getting “instantaneous phase over current” error and increased the PLL Bandwidth from 200 to 300. The bike feels a bit more “stronger/stable”, not faster, upon take off. My take off is gradual, right now, but I’m pretty certain that is in the cycle analyst. I think I have to play with the Again and Wgain a bit more. I’m not getting any A or W limits that are unexpected though.
Field Weakening.
I just tried this. First 5 amps, then 10 amps. I really like the quicker acceleration. I did notice a rhythmic buzzing while lifting the wheel from the ground and applying full throttle. I haven’t heard this before and I thought it may also be Electric Freewheeling. I disabled EF and condition persisted. I then re-enabled it and changed FW from 10 amps to 5. The buzzing was less audible. I turned FW off and the buzzing stopped. I don’t have a temp sensor installed yet, but the extra noise, to me, seems like this would create extra heat. FW is now off and EF is set to 1 amp.
I also increased the battery amps from 25 to 30. Voltage sat is 5 volts at most and the battery quickly recovers. I was reading that voltage sag shouldn’t drop below 90% of the battery nominal voltage, so I think I’m in good shape there. Also, my battery has Samsung 35E and 4P would be a continuous max discharge current is 8 amps, so I’m just under that. I’ve removed the current and power limits from the cycle analyst and all limiting is done in the baserunner.
Really loving the flexibility of the cycleanalyst and baserunner.
^-- i would agree with that, with 10% of the battery input being turned into heat, an enclosed pack is starting to enter the danger zone, heat wise. Lithium batteries take damage when heat is excessive & we don't have adequate safety margin for riding on a hot day to prevent damage.
That's the point where i'd say the battery is probably too small / not powerful enough for the draw being put on it.
Oh, I wrote that wrong. Thanks for pointing that out. This is what I read when I googled the question.
“A voltage sag is considered normal if it doesn't drop below 90% of the nominal value. A voltage sag is a brief decrease in voltage that can occur when there's a sudden change in load, such as when a motor starts up.”
Oh i see. At least you got good advice this time!
I installed turn signals for this very reason. That and I wanted to do something else to my bike. :)
Yeah, extremely low chance most drivers know hand signals. Apart from that I'd also prefer 2 hands on the handlebars while cornering and trying to throttle.
Anyway, I got a 700 series this summer, and I'm looking to start the electrical modding with basically the same turn signals / switch that you're using. The only problem is I'm a total novice electrician.
Lights - https://www.amazon.com/gp/product/B07Y8B5PB9
Controller - https://www.amazon.com/gp/product/B0D6F85PY7
Do you think I need any more hardware than those two pieces?
I'm also assuming I can piggyback off the bike's battery by splicing the right wires. Something like having the running white/red lights tied to the bike lights so that holding + turns on all 6 running lights and the controller handles switching them to amber flashing turn signals. Or turning on/off all 6 lights with the light button on the controller and changing to turn signals with the arrows. Or controlling the 4 add-on lights from the controller and the front/rear running lights operate normally and separately.
Any guidance on how you'd most easily achieve that functionality on an otherwise (electrically) stock bike?
If you're riding like a bicycle does on something that looks like a bicycle, you'll confuse drivers more than you increase safety by introducing motorcycle visual language. My advice is use your hands and don't pretend your bike is something it isn't.
Fetishistic motorist nonsense on bikes just marks you as a n00b and a dingdong.
Recently, the community bike shop where I work was donated a Ride1Up 700 series that had been abused by a previous dingdong to the point that the Hall sensors were cooked and the rear rim was chawed up by riding on a flat tire. I rectified the bike by stripping off every part of the electrical system except the throttle, motor, and battery; then I replaced the controller with a simple dual mode unit and the display with an on-off switch for motorcycle headlights. It's now the simplest version of itself that it can be while still working as an e-bike. Then I filed the burrs off the rear rim and tuned it up.
The only weakness that bike has now is its proprietary inside-the-frame battery. Except for that, it's almost future-proof and certainly much easier to troubleshoot.
At 25-30mph on a city street, Ebikes function more closely to a moped than a bicycle
You'll confuse drivers more than you increase safety by introducing motorcycle visual language.
Any source on that other than your ass?
My advice is use your hands.
Yeah, I figured that much out from you popping up with equally unhelpful advice in other similar threads.
Fetishistic
Holy projection and inferiority complex, batman!
Lol, what do you think a hub motor is?
And introducing yourself into a conversation with no intention to be helpful while gatekeeping around what you think ebikes and bikers ought to be all while calling people who you see as beneath you names makes you an asshole.
If people in general actually knew what hand signals were, that might be effective. Even law enforcement (around here) don't know what they mean, neither do other cyclists or pedestrians, much less drivers of large vehicles.
Using a common signalling language that *everyone* knows, *even non-drivers*, "guarantees" understanding of intention-communication on the roads--blinkers, brake lights, etc., accomplish that handily.
It isn't going to confuse anyone to use a language they understand to tell them what you're about to do, but it certainly can confuse them to move your body around in ways they have no idea what it means and then do something they didn't know you were going to do. :(
These are the reasons I started building and testing and using signal lights on my bikes, after it eventually became reasonably possible to do this myself with what little money I had for lights bright enough to actually be seen, because my lifetime of bicycle riding has shown me that hand signals are ineffective at best (when others on the road or path don't understand them), and dangerous at worst (when large vehicles think you're either waving them over toward you, or any person seeing them thinks you are making some other kind of signal to them that they are offended or angered by and chase you or otherwise attempt to remove you from the road or path. :( )
In places (if there are any?) where hand signals are well-understood by everyone, and other road and path users actually pay attention to them, they are appropriate and perhaps even effective. If that's how it is where you live, it must be nice.
Until I am riding in such a place, I'll keep using the signals that everyone knows (even if they don't use them themselves, and even if they are not paying attention to others' use of them, they still know what they mean, so it's instantly obvious to them what you are telling them with them).
The above is true whether someone is riding a regular bicycle, trike, ebike, skateboard, scooter, or penny-farthing. ;)
Also, in addition, the lighting signals allow keeping both hands (for those of us that still have two) on the bars in traffic for better maneuvering control and much faster access to the bike's controls.
I believe those are 12 volt lights, so you may need a 48V-12V converter to power them. If you don't use a on/off switch from the battery to converter, make sure your shut off the battery when you park the bike, or the converter will run the battery down,
Yes, those are 12v lights. I burned one up using full pack voltage from the native headlight function of the KT controller. Burned the daughterboard. Don’t make my mistake. :)
THANKS! Not directly applicable to my issues, but VERY useful nonetheless !
So, more tweaking. The bike was sluggish, yet smooth, when taking off. I’ve set my torque up ramp time to 5ms. I was reading (might’ve been in the UNofficial ca guide) that the BaseRunner should be set for quick (<100ms) ramp up and cycle analyst will manage throttle ramping.
I’ve also set my throttle start voltage to .86v (throttle off voltage) and throttle max voltage to 4.26v (this is WOT voltage). My throttle min and max are also set to these values in the CA throttle out setting. I’ve also disabled Fast Threshold by setting the amps to zero. This way, I feel not “jump” from Fast Threshold to Ramp Up Rate anymore. I just couldn’t quite smooth that transition. Using only Ramp Up Rate, there is no transition and this contributes to the smoothness of take off.
I’ve also revisited my feedback bandwidth tuning.
For now, this is a very nice setup. I have strong and smooth ramping when engaging the motor for take off. The jitter and stutter are completely gone. I’ll ride it like this until I decide “this is nice but, maybe it can be better.”. I may revisit Fast Threshold, but probably not if everything else is in order.
I’ve been referring to these documents. They were from ASI support page. That page has now changed, but I like these PDFs better.
UPDATE: I've gone back to max 25A on the battery. I felt like 30A was too hard on the battery....maybe. The Samsung 35E say they can do 8A (for continuous discharge). I'm thinking this is the max. 4P would be 32A. I've pulled 30 amps. Voltage sag wasnt much different than the normal 4v sag. I used about 0.5v more on one trip from home to work. The controller that came with the bike was 22A max. I'm thinking that I should stay pretty close to the manufacturer specs, for the batterys sake.
  • PLL Bandwidth.pdf
  • Current Bandwidth.pdf
The next thing I am looking in to is a torque sensor (t15middlewire73). My bottom bracket is 73mm wide. The existing spindle length is 127mm. The new sensor would be 73mm at the bottom bracket and 152mm in spindle length. That would mean my chainring, crankarms, and pedals would all be 12.5mm outward more than they are now. I've placed tape and measured 12.5mm away from where I naturally lay my feet on the pedal. The difference isn't bad and feels OK. I'm more watching the relationship between the chain ring and the rear cassette. The chainline, up front, would change from 53mm to 65.5mm. I'm still learning what this will ultimately mean. I've seen others install their chain ring on the inside of the the claw/spider. That appears to be about 5mm difference and could bring my chain line in to 60.5mm. Maybe that much change won't be anything to be concerned about?
Got my temp sensor installed. Thanks to @GRIN LEVEL, the install was easy. Also found this thread that was more like a teardown. Just waiting for the epoxy to set and will re-install the wheel.
The 3900 sensor I got was 100k. I didn’t realize that when I installed it, but this sensor would give me a negative temperature reading. I tried different settings, but it was a hardware issue. They were the wrong resistance. With the pack of 3900s, I also got some 3435s. The 3435s are 10k ohm resistors and work fine when I select the default 3450 type sensor. Also had to check “Motor Temperature Sensing Enabled” box in the PhaseRunner Suite. I also had to select the "10k ntc, B=3450" in the "Load Temperature Sensor Presets" line. Then the motor temp matched the CA.
Here will be some temperature data. I'll be logging my daily temps for this week and update this post to keep it all together.
I'm using PAS as Thr(0). I think I like it, not sure. I want to play with the number of levels in PAS. I was riding mostly 15-30% throttle, had to hit 80% throttle at the little 14% grade hill. It's maybe 200' long.
Total weight is about 230lbs.
Today is Monday, ambient temp was about 13C this morning. I made my 4 mile commute, riding between 15-20 mph. It was not windy, but the trip is very hilly. and arriving motor temp was 41C. Max was 51C. On the 4 mile trip back, ambient was about 26C and very sunny. Arriving motor temp was 69C. Max was 72C, at the 14% grade hill.
Today is Tuesday, this mornings ambient temp was 15C. After yesterday’s trip, I injected 5A to Field Weakening. Took the same commute and it was a bit more windy than yesterday. Max motor temp to work was 54C, using the same 15-30% throttle. Ambient temp was 21C, on the way back home. Arriving motor temp was 67.1C. My max temp was 72.8C, that was during the 14% hill. Average motor temp, on the way home was 42.5C.
Now it’s Wednesday, it’s very wet and dewy. About 11C. I was running late, that and the threat of rain, I didn’t ride my bike today. Arriving temp was 14C
Ok, it’s Thursday. Rain in the forecast. No biking today.
Friday, finally, I didn’t ride due to possible rain.
I feel like Monday and Tuesday proved that this motor can handle a bit more heat. Like from regen braking. I’ll have to get the regen torque arm before I lock the clutch.
As I continue to tweak and peak my motor by adjusting the Feedback Bandwidth Tuning, my motor no longer operates. I can heard the clutch engaging. I hear and feel the planetary gears moving. No grinding noises. In the PhaseRunner Suite, there are no registered faults. The hall sensors are operating as intended. I did notice that some values were adjusted when I changed settings. I tried auto tune, no luck. The motor fails the spin test. I also tried to reset the BaseRunner. No luck either. I’ll continue to iron this out when I have more time (aka, when the kids go to sleep). Lots of dadding today. Got my V7 Grin torque arm on though.
