Farshad68
Hi
I’ve been reading about my issue with ebike controller in past few days and tried everything I could find (different settings through screen, changing PAS wires, using external 3.5v battery between ground and signal wires of throttle etc.) This is a Chinese (brainpower, Aliexpress, ebay ..) ebike controller 24/36v, max current 13Amp as the picture shows which came with S866 LCD. I’m sure about my wire connections as I checked them almost hundred times. My battery pack is 7S6P Li-Ion 18650 cells 15.6Amp 25.2v (fully charged 29.4v). Controller is 24-36v so I suppose it can be anything in between and not necessarily 24 or 36v, right?! Here are my problems;
- Hubmotor works only in learning mode and when “identification wires” are shorted/connected.
- Throttle changes the turning direction of the motor
- Through LCD setting I can change the voltage from 36v (default) to 24 but then the “walking mode” is like half throttle and just by changing that motor rpm goes way up!
