slaphappygamer
Regular
You may have an extension cable from the controller towards the motor. Follow the cable from the motor. You might find it’s the same plug as your new motor.
Your motor connector appears to have a red o-ring inside it, and is probably threaded? If so, that's why it didn't pull off and got further twisted. I'm not familiar with that connector.
Most low power motors use a simpler Z91 connector, like that ebikling motor. You would have to buy a standard motor extension cable with a Z01 and attach that to your controller to use off the shelf motors. No big thing. Adds $15 to cost of new motor,
This is probably a geared hubmotor. If this is the case, the bolts (six?) on the left side of the motor need to be removed. Then before attempting to remove anything, you should check the right side axle to see if there is a circlip on it.Just the motor, not mounted to a wheel. Is it even possible to replace my old motor without specialized tools?? My initial googling implies the need for a gear puller which I very much do not have.
Parsing spoken language takes too much effort, so I have to learn how to do this on my own before that.
Ah thank you for that detail! I've set the project aside til tomorrow, I ran out of energy for today. It is a geared motor I'm pretty sure. I don't think it has a circlip but I'll check before I do anything. As for the torque arm, I already have a Grin V5, and a second on the way so I can have one on each side. Not making that mistake again!This is probably a geared hubmotor. If this is the case, the bolts (six?) on the left side of the motor need to be removed. Then before attempting to remove anything, you should check the right side axle to see if there is a circlip on it.
pics for reference circlip - Google Search
If no circlip, then simply put the right axle end on the ground, and push the wheel / motor casing downward, and the motor core and left cover will pop right out.
If there is a circlip, then it can be taken off, we'd need to see the type to suggest a good way with whatever tools you have available.
Assuming no circlip, then perform the same procedure wiht the new motor, and then simply swap cores and reinstall with the reverse procedure.
Yeah, in my case it's mostly autism though tinnitus and hearing loss aren't helping. I greatly prefer text communication as well, RTC is exhausting.I have that problem too--realtime communications are difficult; I do much better when I can process and reprocess a text-format, and compose a reply as the thoughts happen, then reassemble them into something ohter people can understand and post it.
(the last couple years' development of my tinnitus/etc has made RTC even harder)
I think a fair number of people on this forum have had taht problem, and most of us act on that last statement pretty thoroughly.As for the torque arm, I already have a Grin V5, and a second on the way so I can have one on each side. Not making that mistake again!
Same as me then...(well, actually I've found that none of us nonneurotypicals (as my brother says) are atypical in quite the same way).Yeah, in my case it's mostly autism though tinnitus and hearing loss aren't helping. I greatly prefer text communication as well, RTC is exhausting.
I'm not 100% sure of the placement of the motor cable.
That's the other thing thats problematic about RTC--other people always expect you to talk to them whenever it is convenient for them, but if you need them, they're not going to bother with you unless they feel like it, and mostly won't deal with non-RTC methods. :/I did call the support line as requested, but caught the guy on a lunch break and he said to call later. I didn't need help so I finished up and just called him when it was time to put the battery in and fire it up, my intent was to let him look over everything before I turned it on. Except he didn't pick up.
Ahh thank you, that's exactly the kind of advice I needed! The factory tightened everything down really hard, so much so that the cable couldn't move at all, and the instructions actually tell you to make sure the motor is installed so that the cable exit points upwards! I don't ride in the rain, but the extreme humidity of the region means condensation is a thing I have to be mindful of. Tomorrow I'll make adjustments.The main things I would recommend:
ensuring there is enough loose cable so that any amoutn of wheel flop or steering or whatever, even when parked somewhere that someone might move things when you are not there, will not strain the cable, or rub it on other things.
installing the motor in the fork so the cable exit points downward, and having a "drip loop" so water tends to run down off the cable instead of into the motor. (kind of like how you teach a dog to walk beside you with the leash in a J hanging loose between you)
Not tightening any zipties holding it down too tight--i'd leave it so the cable can still slide underneath them. too tight and they can damage wires inside teh jacket if the cable gets pulled on.
Yuuuup. I called at several different points and always talked to one of two people, I think that's the entirety of their customer support team. Which is fine, but then don't expect stuff like having a customer do stuff with CS on the line. I'm just glad I had the ability to fix things myself and didn't actually need help beyond them supplying parts.That's the other thing thats problematic about RTC--other people always expect you to talk to them whenever it is convenient for them, but if you need them, they're not going to bother with you unless they feel like it, and mostly won't deal with non-RTC methods. :/
A good point! I'm pretty sure the only thing broken is the cable.I’d hang on to that other motor. You might be able to use the clutch (or something else that isn’t broken) from the old one if anything ever breaks.
I expect the upside down instructions were to accomodate a cable-length issue, or they think that having the drip loop hanging down is a catch-on-things risk (it is, but worth it to better ensure dryness inside).The factory tightened everything down really hard, so much so that the cable couldn't move at all, and the instructions actually tell you to make sure the motor is installed so that the cable exit points upwards! I don't ride in the rain, but the extreme humidity of the region means condensation is a thing I have to be mindful of.
I originally started learning computers / etc because I couldn't afford to pay anyone to fix them for me, but eventually that and all the other things I learned helped me just get stuff done without having to deal with "support" or depend on other people who don't really want to help do the specific thing that *I* need to do, whatever it is at that moment.Yuuuup. I called at several different points and always talked to one of two people, I think that's the entirety of their customer support team. Which is fine, but then don't expect stuff like having a customer do stuff with CS on the line. I'm just glad I had the ability to fix things myself and didn't actually need help beyond them supplying parts.
Unrelated to the above, something I forgot to mention is that in order to install the inferior axle plate that comes with the trike, you have to torque out the axle a bit. That is, the plate won't match up to the fork unless the axle is rotated in the dropout slightly. I'm no expert but that doesn't seem quite right to me.
Ditto.I’d hang on to that other motor. You might be able to use the clutch (or something else that isn’t broken) from the old one if anything ever breaks.
Often, when there's cable damage, it blows the hall sensors, so they need replacing as well as the cable. They're easy to test with a meter.A good point! I'm pretty sure the only thing broken is the cable.
Haha thanks, but to be honest I have a lot of experience in being a polite pest in order to get service. I have a lot of health problems and getting them dealt with tends to require a huge amount of persistence and assertiveness.You did well, Snowfox. I'm mildly surprised that on an under $1,000 DTC etrike you got as much warranty help as you did.
I like to keep a tally on what it costs me to make a cheap bike serviceable. There is an art involved.
