Hello,
There have been already some post about 250W hub motors with integrated Kclamber cassette torque sensor:
Yose kit
Truckrun RN04
Truckrun seem to also offer a larger version: the rw28, up to 1000W, in both cassette and freewheel version, with l1019 motor cable. For more clarity and easier search, I created this new thread dedicated to the latter motor.
I've received the complete data pdf from a chinese reseller - see attached file. The name (AKSM001) suggests a rebranded aikema motor, manufacturer of the infamous q95, q100 and q128 hub motors. According to the same reseller, gear ratio is 1:4.3 and motor weight 5.2Kg. That would make it one heavy geared hub...
Very similar to the 750/1000W bafang geared hub.
According to the truckrun homepage, the rw28 should be available with cassette tq sensor - though I could not source one yet, and the pdf doesn't show a torque signal.
Finally, should I manage to get one, there is still a major difficulty with these motors: the limited numbers of data wires available on most motor cables doesn't allow for a direct analog transmission of all information (speed, temp, torque, cadence). Hence manufacturer choose to encode data into an uart signal - which has to be decoded on the controller side. So either you have to get the exact matching controller to your motor ... or you write your own uart decoder in lispBM for an example.
Fortunately stancecoke already did the tedious job of investigating this custom protocol on a german forum, so all there is left to do is some translation
Yose kit
Truckrun RN04
