BBS-FW tool - help with two profiles - extra amps? BAFANG
Fuzzynuts
🔌 New-ish
Yorkshire
Hey guys -
I flashed my BBSHD firmware and programmed in a 250w profile that comes on by default max speed 25kmh
I put the 2nd profile to my light+ On button trying to give it the full beans with PAS plus thumb throttle.
thing is all it does is nudge the wheel so im not understanding the options for it - i wanna use both peddle and thumb throttle for turbo mode.
I've also been told i can use the full 30 amps on my battery for a bit of extra power?
Can you guys help me out setting up my profile..
I went with these settings for the max current per profile
7
10
14
19
26
36
50
70
100
Well, you should show us what you really have there, as we can see you haven't even enabled
the throttle there yet. The numbers you gave are irrelevant(levels other than 2 being disabled).
Not going to guess any further.
Something to read:
But i'll add some hints;
1) diff between 7 and 10 is likely something you'll have a hard time to even notice, so just leave
the level 0 being at "disabled" - is very useful to have a level w/o operation for cases where you
want to turn pedals w/o motor without shutting it down.
2) should choose "PAS" for those "Motor Disabled"-levels above level 1.
3) obviously enable the throttle(see "Enable Throttle"-checkbox) for each level you want to use it with.
4) it might be you want the "PAS Variant" to be "Variable".
I ended up sorting it out a guy was using the same software as me and gave me his readings for the same set up, applied it and it works.
