Hey Endless-Sphere community,
I wanted to share my latest project. I am a 20-year-old student from Belgium, and my 2022 Sur-Ron Light Bee had been sitting idle for a while. When I wanted to revive it for my university commute because gas prices are insane, I found out the stock battery was completely dead. Too many cells were degraded beyond saving.
Looking online for a replacement OEM battery, specifically the older 2020-2023 60V stock versions, the absolute cheapest brand-new stock replacement I could find on the market was 1300 euros. Since I had a strict total budget of max 500 euros, buying a retail replacement was completely out of the question. I decided to leverage my previous DIY home-battery experience and design my own replacement pack instead.
I spent a solid month purely on R&D, 3D designing, and troubleshooting just to get everything to fit perfectly and function seamlessly. I have been in the middle of a brutal 3-week university exam period while finishing this up, so sleep has been completely optional, but it is finally alive and currently in the Design Validation Stage.
Before building, I ran capacity tests on these BAK cells. At a 1A discharge rate, they tested at a real 4850 mAh, which brings the total real-world pack capacity to a solid 34Ah. With a 7P configuration, these 15A BAK cells give me a combined 105A continuous discharge capability, which is perfect for the 90A demands of a stock Sur-Ron setup.
QUICK SPECS OVERVIEW:
For the main internal power leads, I used ultra-thick 8AWG wire for the positive terminal (+). For the negative terminal (-), I ran triple 12AWG wires (3x 12AWG in parallel). This gives me massive current capacity while allowing enough flexibility to route the wires safely inside the tight enclosure.
Because welding copper requires an insane amount of energy, my capacitor spot welder was pushed to its absolute limits:
A lot of people might wonder why I am not building a fully overpowered, high-voltage battery for Europe straight away. Since I live in Belgium, tuning laws here are incredibly strict. If the police catch you with a heavily modified, overpowered bike, they will immediately confiscate your bike on the spot and hit you with a massive fine. That is why for Europe, I prefer keeping the bike looking and acting stock, allowing you to rely on the secret handlebar brake code to easily toggle the limiter on and off when needed.
To make this stealth setup work flawlessly, I am currently developing the communication protocols and want to know what the community prefers. Which feature should I focus on first?
If there is serious interest in these batteries, I am planning to launch a crowdfunding campaign to make this a reality. Before I can legally sell or ship anything in Europe, the pack needs to be officially certified, which requires passing the strict UN38.3 testing standards. This certification process alone costs around 8,000 to 12,000 euros.
The crowdfunding will also allow me to invest in proper manufacturing machinery. I need a much better, high-end pneumatic spot welder to work way faster, and I want to transition to using pre-cut, custom-ordered copper busbars. Eliminating the manual cutting phase will save an insane amount of labor hours, which will ultimately reduce assembly time and drop the final cost for everyone.
I can only achieve this scale, certification, and pricing with your help and feedback. Let me know what you think of the design, the specs, and which direction I should take first.
Cheers from Belgium.
THE SPECS AND THE CELLS (NO ALIEXPRESS GARBAGE)
When it came to the cells, I refused to gamble with sketchy webshops or AliExpress knock-offs because safety is my number one priority. I bought raw, bare A rated BAK 21700 5000mAh (15A continuous) cells directly from NKON, which is the most trusted supplier here in Europe, for around 1.45 euros per cell.Before building, I ran capacity tests on these BAK cells. At a 1A discharge rate, they tested at a real 4850 mAh, which brings the total real-world pack capacity to a solid 34Ah. With a 7P configuration, these 15A BAK cells give me a combined 105A continuous discharge capability, which is perfect for the 90A demands of a stock Sur-Ron setup.
- Configuration: 16S 7P (Modular design: can adapt to 16S 8P or 20S 6P)
- Real Capacity: 60V 34Ah (~2.04 kWh) - Tested at 4850mAh per cell
- Cells: Genuine A rated BAK 21700 5000mAh 15A From NKON
- BMS: 2 options of JK BMS "same PCB size" (Supports 100A-200A continuous / 200A-350A peaks)
- Busbars: Copper strips + steel strip sandwich structure for ultra-low resistance
- Total Raw Material Cost: ~480 euros (~160 euros for 112 cells, rest for BMS, copper, cables, case, etc)
THE BUILD PROCESS AND HEAVY-DUTY INTERNAL WIRING
Building this pack was a massive test of patience. To keep internal resistance as low as humanly possible, I went with a 0.15mm copper + 0.2mm steel sandwich structure (10mm wide) for the busbars. To distribute the massive current load evenly across the pack, I split the series connections across 5 individual parallel strips.For the main internal power leads, I used ultra-thick 8AWG wire for the positive terminal (+). For the negative terminal (-), I ran triple 12AWG wires (3x 12AWG in parallel). This gives me massive current capacity while allowing enough flexibility to route the wires safely inside the tight enclosure.
- I had to wait 15 seconds between every single spot weld just for the capacitors to fully recharge.
- Every 15 minutes, the welder got so hot I had to stop and force-cool it under a fan.
- In total, the assembly and welding took me about 8 hours of non-stop, intensive labor, but the rock-solid connections were worth it.
REAL-WORLD TEST RESULTS
I just finished the first real-world torture tests, taking it off-roading and trail riding. The results:- Way Less Voltage Sag: The original stock 32Ah battery is notorious for dropping an insane 7V to 9V under full load, which kills your top speed. In my real-world tests, this custom pack showed a drop of only 0.3V per cell (from 3.6V down to 3.3V). Since it is a 16S configuration, that recalculates to a total pack sag of just 4.2-4.8V under load. Thanks to the BAK cells, copper/steel sandwich, and 5-strip series layout, we cut the original voltage sag nearly in half. The power delivery stays completely consistent even below 50 percent capacity.
- More Top Speed: I can still hit 70 km/h even when the battery is running low. On a full charge, it hits 80 km/h effortlessly, something my original battery never achieved.
ENCLOSURE, SAFETY, AND FUTURE 52AH UPGRADES
- Current Prototype: Printed in PETG-GF (Glass Fiber) with a 3mm wall thickness. It has survived heavy vibrations and rough terrain perfectly.
- Future Production Plan: If I bring this to market, I will transition to an aluminum extrusion housing for maximum structural safety and weatherproofing.
- Weatherproofing: Internal silicone seals, waterproof gaskets, and a dedicated internal compartment for a custom silica-gel packet to absorb any potential internal moisture.
- Aesthetics: The front will feature a clear tinted plexiglass window, allowing you to see the JK BMS status lights and check for moisture at a glance, while looking incredibly sci-fi.
- Future-Proof Modular Design: In the future, when the new BAK 65E (6500mAh) cells roll out, I designed this exact same enclosure to adapt perfectly to a 16S 8P configuration. This means you can build a massive 52Ah battery inside this exact same footprint with absolutely zero modifications to the bike. No battery lid extenders, no new bottom plates, nothing. You just slide it right in, connect it, and ride.
FUTURE PLANS: I NEED YOUR FEEDBACK
My ultimate goal is to bring the 60V 34Ah pack to the European market for around 850 euros. I want to offer this with zero compromises on safety, which means taking a massive cut on my own profit margins. Honestly, I do not mind at all because this is my absolute passion and I want to make good batteries accessible.A lot of people might wonder why I am not building a fully overpowered, high-voltage battery for Europe straight away. Since I live in Belgium, tuning laws here are incredibly strict. If the police catch you with a heavily modified, overpowered bike, they will immediately confiscate your bike on the spot and hit you with a massive fine. That is why for Europe, I prefer keeping the bike looking and acting stock, allowing you to rely on the secret handlebar brake code to easily toggle the limiter on and off when needed.
- Option A: A custom handlebar-mounted JK display screen showing real-time voltage, percentage, precise Amps in/out, and temp data.
- Option B: A custom protocol-translator module that talks directly to the stock Sur-Ron controller, keeping the OEM dashboard fully functional so the secret limiter code remains active.
