So I'm amazed that it actually has been 13 years since I had this stack!!! I think it is almost time that I rebuild the Stealth Fighter #86. The poor beast has been in storage ever since. Anyhow hope to start to get some good ideas and updates from the community as this build starts.
Please share your rebuild/build up with us here. I look forward to it. Fighter 86, was that the larger frame fighter designed for the headway cells?
I wouldn't open the V-Boxx without watching those three videos first... you risk never putting it back together again!
it's easy to open and close the v-boxx with no problems that's why it was unnecessary for any service diagrams.
has anyone who bought a new Stealth bike make a warranty claim within the warranty period for any failed part on the bike.
i understand there warranty is limited to certain parts on the bike.
Stealth bikes sand warranty.
Google AI Overview
Riding a Stealth bike in sand will strictly void your warranty. The fine, abrasive nature of sand enters moving parts and electrical housings, which drastically increases the mechanical and electrical load on the bike's components. [1, 2]
Warranty Coverage Breakdown
  • Frame and Swingarm: Hand-built using aircraft-grade alloys, Stealth Electric Bikes covers the monocoque frame and swingarm under a conditional Lifetime Warranty. [1, 2, 3, 4, 5]
  • Parts and Electronics: General mechanical and electrical components (motors, controllers, and displays) carry varying standard warranties, often ranging from 1 to 2 years depending on the specific model and your purchase agreement. [1, 2, 3]
  • Exclusions: As is standard across the Stealth Warranty Policy, coverage is for the original purchaser only and does not extend to normal wear and tear, incorrect assembly, or damage caused by misuse, abuse, or accidents. [1, 2]
Additional Information
The hand-built frames feature a protective zinc undercoat and tough powder coating to defend against corrosion. However, care must also be taken with water, as excessive exposure or full submersion is explicitly prohibited. [1, 2, 3]
i had to check Stealth bikes water warranty.
Google AI Overview
Stealth Electric Bikes do not cover water damage or humidity under their warranty. Because these high-performance models (such as the Stealth B-52R and Stealth P-7S/R) contain sensitive electronic components and displays, exposing them to rain, puddles, or high-pressure hoses will void your warranty. [1, 2, 3, 4]
Key Warranty & Maintenance Details
  • Environmental Exclusions: Water, humidity, and "Acts of God" are explicitly excluded from warranty claims by Stealth. [1, 2, 3]
  • Cleaning Best Practices: Do not use a pressure washer or a direct garden hose to clean your bike. Instead, rely on a gentle sponge bath using warm water and an eco-friendly soap. [1, 2]
  • Chassis & Components: While the frame and structural swingarm often come with a Lifetime Warranty, the electrical systems (battery, motor, and controller) usually carry separate 1 to 3-year guarantees, all of which are nullified if water ingress is found. [1, 2, 3, 4, 5]
  • Warranty Support: You can review the full guidelines on the Stealth Warranty Policy
i'm reading page 9 and i'm already learning some things.:bigthumb:
I´ve got some questions concerning the V-Boxx gear unit. The instruction book asks for an oil change ever 2500 Km. I´ve used 150 ml of a chain cleaning solution to wash the internal gears of the old oil.
New V-boxx came with liquid fat.
I use fat made for central lubrifications systems on large trucks
I think you might mean "grease" rather than "fat".
Fat is dead animals.
Grease is a lubricant.
Sorry. I ment grease.
The gearbox calls for grease NOT oil, very big diff.
  • Like
Reactions: Rix
i have battery chargers for RC nitro & electrics and i like the lipo battery storage mode with those chargers.
why does the simple stealth charger not have a daily storage mode if my batt is at 60% and only want to charge to 80% i'm going to have to guess when to turn off the charger when it reaches 80%.
Google AI Overview
Most standard e-bike chargers, including the one for your Stealth B-52, lack a "storage mode" because they are simple, dedicated bulk chargers. They are designed to do one job: push a constant current until the battery is full, then shut off. Here is why they do this and how you can store your bike safely. [1, 2, 3]
Why your charger lacks a storage mode
  • It’s a bulk charger, not an analyzer: Storage modes are common on expensive RC hobby chargers (like those made by iCharger or Traxxas) that allow you to set specific cell counts and chemistry types. The Stealth charger is a heavy-duty power supply designed specifically for a large, proprietary 72V or 84V pack. [1, 2, 3]
  • No discharge capability: A true "storage mode" requires the charger to pull power out of a fully charged battery to bring it down to a resting state. The standard Stealth charger only pushes power in. [1, 2, 4]
  • The BMS does the heavy lifting: Your Stealth B-52 battery has a built-in Battery Management System (BMS). Its primary job is to monitor cell voltages and prevent damage, balancing the pack during the final stages of charging. [1, 2]
How to store your battery correctly
For long-term storage (such as over the winter), you should store your battery at about 60% charge. [1]
  • Check the voltage: Never store your battery at 100% or completely empty. A fully charged or fully depleted lithium battery puts extra stress on the internal cells. [1, 2, 3]
  • Monitor it: If you aren't riding for a month or more, check the charge every few weeks. Top it off for a short cycle if the capacity drops too low. [1, 3, 4]
when i bought my bike used it had 87% batt capacity i then rode it a few times until it reached 67% then connected the charger.
i had the charger on for 20 mins then turned it off and turned bike on and it had the same reading 67%, i did it again for 20 mins and once again 67%, i continued with charging for another 40 mins and now it has 100%, i was expecting to see a percentage increment change during the on and off charging process but i didn't see that.
i think next time when charging i'll just check the display screen batt volts when to turn it off.
My last three Stealth bikes including my current B52R do the same thing, The battery meter indicator on the DC1 wont trip to 100% until you get past a certain voltage during charging. If you charge it and toggle the key to power the bike on and off, you will see some increments during charging up to 100%.
Hey Rix,
i came back from a ride with the battery at 57% and 86.8v and i put in on the charger for 40 minutes and turned the bike on and it still at 57% but with 90.1 volts, i did toggle the power key while the charger was off a few times and it didn't change the percentage at all.
Wednesday's ride. GPS Confirmed top speed of 61.35MPH, or about 99KPH.
that must felt fast and so close to 100.
  • Like
Reactions: Rix
Hey Rix,
That's pretty close to what I have, at 83.8 volts, I show 54% and then when I charge and volts exceed 90 volts, it goes to 100%. Yah, it felt plenty fast at 99kph. More than happy with it!
yep exactly, there is no other display reading than 100% when charging it...it's too bad if you want to charge it to 80% that can't happen.
wow, stealth bikes recommends to have the battery fully charge wherever possible.
that bad don't do it..charged it to the storage capacity "good luck with that" if it's not being ridden that day.
this statement is contradicted to there above statement.
the stealth display is not capable of giving a correct battery percentage when charging from 50%.
when i have been charging and the 2 red charger lights are on i can turn the charger off and then turn the bike on and it has 100%. And it should not show 100% because the the green light on the charger did not come on.
i set mine to max out at 70kph and it felt fast..why doesn't the bike have a top speed display reading, all i have is the average speed display.
That I don't know, the DC1 probably has the ability to set and display that, but I don't know where that would be or if its in the advanced menu which I don't know how to access on the latest generation.
You can get it close, for me, around 82-83 volts and toggling on off switch every two minutes allows me to bring it to 80-81% for me.
It doesn't have a memory effect day to day. But yah, as your photo below denotes, if stored at full charge for months, the battery will downgrade at a faster rate than if storying at 55-65% SOC.
Yah, if you toggle on and off every few minutes, you will see the charge percent rise more gradually but only to a certain point, than some where around 90 volts on the charger, SOC jumps to 100%. But if the voltage sags below 89 volts after unplugging the charger (before full charged), and volts drop to around 89 volts, I have noticed the SOC drop anywhere from 91-97% after toggling the on off. Conversely, if I charge past 91 volts, and unplug the charger, voltage drops to 90.4-90.6 volts and the SOC is still 100%. Not sure how the DC1 is programmed for active SOC readings, but I am getting more familiar with what to expect.
Hey Rix thanks for the comment.
With regards to the battery percentage it seems if the user wants a accurate battery reading then charge the battery to 100% and then when it's ridden the battery percentage reading will accurately drop while it's being used.
When the battery reading is say for example at 50% and it needs a charge for the most part "Stealth co." wants the user to charge it to 100% went the green light on the charger comes on.
Yah, I noticed that and reached out to Stealth. Summarizing, the "%SOC" is based on active volts the DC1 is reading at any given moment. So lets say you are in competition mode, which draws a lot more current than sport and eco mode, your volt sag will be more, and you will get whatever % reading with the volts at the lowest level. Then when toggling the bike off and letting it sit for few minutes, the volts in the battery increase a little, and the % of SOC goes up with that surface voltage increase. Then blip the throttle put a load on it, and the SOC drops. Just the way it is. As I get more familiar with the DC1, I am accurately anticipating these trends with both charging and discharging. Just like when charging, after a certain point, the battery voltage % will read 100 percent whether the volts are at 92 or 91. but when it gets below 89, then we start seeing the percentage drop. This is worse the higher the performance mode is. When I get home from a ride, I put it on the charger immediately, I do the first check in 15-20 minutes. After my last ride, my SOC went from 39% to 70% in 20 minutes, but when I stopped the charger, the voltage settled and my SOC drop to 63%. Perfect for storing. When our settled voltage no load on the Bomber battery is between 81-84 volts, that ideal storage volt range. Keep monitoring your machine, and you will see the patterns with the SOC that I am blabbing about here.
to be honest my bike is 2018 with the original battery and it holds it's charge good as well as the riding discharge load performance for a 8 year old battery, it could still be good for a few more years or more.
i just full charge the battery before riding and use up at least minimum of 20% so at most it will have 80% when i come back.
  • Like
Reactions: Rix
