logalex
Hi everyone,
After a long search, several attempts and testing different controllers, I finally found a Mqconn Sabvoton SVMC7248 that works very well with my Super73 ZX. Motor and battery are original Super73. Controller stay very cool on testing I have done untill now.
The important thing for me is that PAS works correctly with this controller. The bike responds to pedaling and the motor assistance is activated as expected.
However, I am having a problem with the PAS assistance levels controlled by the display.
I purchased a complete kit from MQCON, consisting of:
Sabvoton SVMC7248 controller
MQCON TF-M8 display
The display was recommended by MQCON as being compatible with this controller.
www.sabvoton.net
After installing everything, the display shows an E006 error. From what I have found, E006 may indicate a communication problem between the controller and the display, but I have not been able to confirm the exact meaning of E006 for the SVMC7248 + TF-M8 combination.
More importantly, changing the PAS level on the display does not change the motor assistance level.
For example, if I select:
PAS 1 → full motor power when pedaling
PAS 2 → full motor power when pedaling
PAS 3 → full motor power when pedaling
There is essentially no difference between the PAS levels.
Even more strangely, if I set the display to PAS 0, I would expect the pedal assist to be disabled. However, the motor still provides full power when I pedal.
So at the moment, PAS itself works, but the PAS level selected on the TF-M8 has no apparent effect on the controller's power output.
The behavior is basically:
PAS 0 → motor assists at full power
PAS 1 → motor assists at full power
PAS 2 → motor assists at full power
PAS 3 → motor assists at full power
The controller otherwise appears to work correctly with the bike.
There is one more detail that may be relevant. The TF-M8 display has two connectors. I connected connector #1 to the controller, as shown in the attached photo. However, I cannot find any corresponding connector for connector #2 on the controller/wiring harness.
What is connector #2 supposed to be used for? Could it be related to the PAS levels or to the E006 error?
I have already contacted MQCON/Sabvoton about this problem, but unfortunately I have received no response for more than two weeks, despite asking for technical assistance.
I am therefore trying to find someone who has experience with this exact combination:
Super73 ZX + Sabvoton SVMC7248 + MQCON TF-M8
and, ideally, someone who knows what E006 means specifically on the TF-M8/SVMC7248 combination.
I am not looking for general advice about how PAS works. I am specifically trying to understand why the PAS level selected on the TF-M8 does not appear to be controlling the assistance level of the SVMC7248, and whether the E006 error is related.
If anyone has experience with this controller/display combination, I would really appreciate any information about compatibility, firmware/protocol differences, PAS configuration, or known issues between the SVMC7248 and TF-M8.
I can also provide photos of the controller, display, wiring/connectors and the current configuration if that helps.
Thanks in advance to anyone who has experience with these Sabvoton/MQCON systems.
MQCON TF-M8 display
MQCON(Sabvoton) SVMC7245 72V1500W 45A Brushless DC Motor Programmable Controller For Ebike Bicycle
Sabvoton SVMC programmable sine-wave motor controller enable you enjoy the good quality,high performance and a good price at same time!
www.sabvoton.net
