2 self-build ecars later
I am converting a lawn tractor to electric. I have installed a 48v 1000W brushless Chinese rear transaxle. It has Hall effect wires which connect with like wires from a compatible 48v 1000W motor controller.
With learning wires connected, and wheels off the ground, the motor works and the rear wheels spin forward at full rpm.
I also installed a foot throttle said to be Hall effect. The controller has red, green and black wires labelled accelograph. The foot throttle has 3 like wires, red, green and black which I joined to their like controller wires.
With learning wires disconnected, and wheels on the ground, there is no motor start and no wheel movement. Everything I've read says those wires should be disconnected once you have forward wheel movement, which I have.
I have not installed a display so have no error codes.
No use asking the Chinese supplier - either doesn't know, hazards a guess, or says it should work!
Today I tried another foot throttle but no success. Voltage readings on both foot throttles are appropriate according to TC with whom I've already been in touch.
The motor, controller and both foot throttles come from the same supplier.
Grateful for any advice. No shorting of any wires, no touching of the throttle wires with hv wires.
I assume the black ground wires do not have to be separately grounded say to the chassis, but joined as I have done, with grounding provided by the controller from where its black wire comes.
