friendly1uk said:That's good news indeed. Thanks for sharing. Are you sure they are genuine though? I can't think why Panasonic would leave their name off them.It seems rather unconventional.
riba2233 said:Here are the details for the bms:
https://bmsbattery.com/bmspcm/714-10s-13s-20a-lithium-bms-for-bottle-battery-09-bms-pcm.html
36V battery uses 10 cells in series, 5 in parallel; 48V uses 13 cells in series, 4 in parallel. That is 52 cells, and there is space for that, as you can see on pictures on first page.
oobagooba said:Any way to raise the discharge current to 25a on one of these?
thetimmy said:riba2233 said:Here are the details for the bms:
I impressed that a single BMS can be used for both the 48V and 36V?
Would I be able to use this soldering ironhttp://www.amazon.com/Hakko-FX888D-23BY-Digital-Soldering-FX-888D/dp/B00ANZRT4M/ to assemble the cells or would I need more specialized equipment?
riba2233 said:Sure, there are many BMS's out there to buy...
d8veh said:. Recently, I had to replace the charging socket in one of my batteries. For that, I had to remove the USB connector to get at it.
but I can't remember what was on the pcb.
d8veh said:You're right concerning the BMSBattery version. Now that I think about it, I remember that Cwah's USB module was on the BMS pcb. Recently, I had to replace the charging socket in one of my batteries. For that, I had to remove the USB connector to get at it. I can remember a pcb attached to the USB connector that screwed to the case and was joined to the main BMS pcb by two wires, but I can't remember what was on the pcb.
There's some photos of Cwah's BMS here:
http://www.pedelecs.co.uk/forum/threads/new-bottle-battery-under-the-rain-is-dead.19920/
There's other versions of the battery with different BMSs, so they might not all be the same.
greg00 said:I've been using the 48V Panasonic version from BMSB for a few weeks and I like it.
With the BBS02 500W I can reach 50km with light hills (total 600m elevation) - with casual pedaling and open throttle mostly.
But I have some trouble with the USB port. It seem's to work on other devices but the iPhone5.
I haven't checked the Volt output of the USB port since the iphone is kinda picky.
Can someone check the Volt output and if it would charge their iphone?
Thanks
