777arc said:Figured it out! Vedder does not use version control for BLDC-Tool, but if you look at the commit history, go to the commit on Feb 19, 2015 and click the button that says "browse the repository at this point in history". Then click download zip, unzip it, open up terminal, cd to the folder, qmake, make, then open up BLDC-Tool. This is the version of the tool from Feb 19 - April 11, so it is likely the right one. It seems to work for me (i.e. connect and read/write config work).
Did you make sure to disable all control (such as PPM control), and 'reboot' the VESC? Otherwise the detection doesn't work.777arc said:When I hit the sensorless parameter detection button with default parameters, the motor does not move, but I'm afraid to mess with the detection parameters because I don't really know which direction I should change them and how much. I have a 149kv motor at 6S. 6A should definitely be enough current for the motor to spin up, but I have no idea about what "Min ERPM" should be (default is 600).
erwincoumans said:Did you make sure to disable all control (such as PPM control), and 'reboot' the VESC? Otherwise the detection doesn't work.777arc said:When I hit the sensorless parameter detection button with default parameters, the motor does not move, but I'm afraid to mess with the detection parameters because I don't really know which direction I should change them and how much. I have a 149kv motor at 6S. 6A should definitely be enough current for the motor to spin up, but I have no idea about what "Min ERPM" should be (default is 600).
ls /dev/tty.*
screen /dev/tty.[yourSerialPortName]
onloop said:Hi Vedder, technically speaking/ operationally speaking... what happens when Dual VESC are powered on and operating but the canbus loses connection to the slave VESC momentarily due to vibrations etc?.... I know what happens physically, one motor stops responding.. So simply power cycling the system and both VESC are operating both motors again..
So my question is, if the canbus interface briefly loses connection does it forget there was another VESC connected?
If possible could you modify the software so it is constantly checking for slave VESC connection via canbus, then it can automatically re-detect the slave if connection is lost...... the tiny little JST plug seems a bit temperamental at times.
I might solder the wires on permanently.
kwoolf1 said:Another update. Today I flashed the new firmware Version 1.1 to the Enertion VESC. I used a STM32F0-Discovery board and got it to work after trying a few times. Seems I had to to unplug everything and let the VESC and discovery board 'reset'. It's working!
Also got my nunchuk to work so will try that out for the first time tomorrow.
onloop said:Hey kwoolf.
Can you please create a step by step tutorial on getting nunchuck to work. Including photos. How to connect the receiver etc.
okp said:hey!
just back from holidays, that was refreshing! I got my two VESCs from onloop on my mailbox. Great as it took a while for the post office to reach me
my actual setup is :
- dual diagonal two
- Twin 150Amp 2-12S Opto ESC (replaced by two VESCs)
- 2 x 63mm Alien motors, 170KV, 3200watt, 80Amp
I just went quickly through the thread and I read the warning to configure the VESCs for the motors.
So I am about to install ubuntu and bdlc tool.
I am still at the hotel in Morocco on my way back home, but just wondering (I am OK to install ubuntu)
- how I connect the two VESCs together
- how I configure/connect VESC to my computer
- does anyone have my motor settings to put in VESC or do I need to get them from my actual APS ESC configuration (or put the same?)
- is there a wiki or a how to updated regularly, just to ensure all the latest information is available (installation) as the time goes by
thanks a lot!
can't wait to get back on my eboard, hopefully for a full review and ride test of the VESC this saturday.
sudo usermod -a -G dialout yourusername
stty -F /dev/ttyACM0 -crtscts ixon ixoff
