torqueboards
Lol.. lots of people must live on the top of a hill. I don't ever have an issue over charging a battery pack through re-gen.
torqueboards said:Lol.. lots of people must live on the top of a hill. I don't ever have an issue over charging a battery pack through re-gen.
I agree.Right. First let's solve the problems we actually have -- namely, a good ESC. If, after that, we find a substantial number of people wrecking batteries because they live on top of a hill, we can talk. But really I'll just tell you to charge to 4.1V/cell and leave room for that initial downhill segment.
speedfast said:Hi,
if we use your esc with hall sensors and that there is a problem with one sensor (burn, dissolder, disconnect ...) during a ride .
Is it possible that the esc will switch in sensorless mode automatically ?
Vedder wrotte :
I haven't implemented that yet, but it could probably be done quite easily. I haven't used hall sensors much yet, so the sensorless part is where I have spent the most effort by far. Is there a specific reason why you want to use hall sensors? Unless you have an application like a servo that switches direction all the time, running sensorless should be better.
okp said:what about LiFePO4 batteries? I used to try them when i was in 3D RC copters
speedfast said:It is my first project with electric motors ... I m beginner
But i read a lot and i like these DLRK .
I was thinking that sensored will be ever better than sensorless mode and that the main interest of sensorless is to reduce hardware issues .
And i was thinking that now, sensorless mode with the latest implements was very very near efficient that sensored mode .
But you seem to said that sensorless mode has better performance than sensored mode . Why ?
You use FOC for sensored too ?
If it works exactly the same, i will use in sensorless mode .
It's just that i have already the motor and the sensors .
RPM in the video is measured in electrical RPM, so you have to divide the value by 7 to get the mechanical RPM since it is a 14-pole motor.Is the RPM counter correct? seems really high.
W = joules / secondit would be great if you can add some more power use data, such as average Wh use per second. or real time Wh use per second. Or peak Wh per second & avg Wh, or a chart that shows total battery Wh and shows Wh consumption in real time & as a percentage of the total.
this data would make it easier to see how to make the most efficient board. also when using the pneumatic wheels it would be good to know if they are much worse in efficiency when compared to other wheels.
sweet video. How do you get all this telemetry information ? Are you using an eagletree logger? thanks!
Thanks!Damn good work Vedder!
How do you connect the ESC to the computer? Is that wireless?
Thanks! I would like to order one more version of the PCB though, because I made a small adjustment to one of the current shunt paths to get better current readings. I will also send my prototype to Austin and let him test it.Yes very good work! I think its ready for group buy. This is probably more testing than the chinese companies has ever done
