gensem
8ah zipps are awesome!
looking forward to get one lite bms from you.
GGoodrum said:With the Zephyr charge controller, there was an auto-shutoff function that monitored the charge current, and shut off the charge current, and the main LED, when the current dropped below a preset level. For the Lite variants, what will happen is that the LED will stay on, and be solid green at the end of the charge process. If the individual red shunt LEDs are off, and the LED is green, the charge process is complete. Unplugging the charger/supply, at that point, resets the circuit and the LED stays off until the next time the charger supply is connected. During the CC charge phase, the main LED will be orange. If there is an imbalance, the shunts for the high cells will come on, along with their respective LEDs. Once the main LED is green and all the shunt LEDs are off, the pack is fully charged and balanced.
-- Gary
o00scorpion00o said:Hi Gary,
With this bms, will the bms stop drawing current or do you (have to) disconnect the charger?
I'M assuming anyway that the charger will switch itself off when it senses the current has dropped below a certain point, correct?
Will you also sell chargers, or recomend chargers for this bms?
Please do a 16S 2P version!
Mark
auraslip said:Love it. Can't wait to start building.
I want to echo the sentiment, "What took you so long!" This is THE ebike product that will make building a bike easy and affordable. Now I can build all my friends bikes for what? $200 for 4x lipo packs, $25 for a KP charger, and ~$50 for your board? Cheaper than a ping, much more expandable, arguably more reliable, and almost as easy. I LOVE IT.
auraslip said:On a practical note - it's gonna be a PITA to ship assembled boards with both ends sticking up like that. Probably no easy way to fix it, and it'll only cost a few dollars more to box it up safely, but it adds up ya know?
The end plates attach to the ends of the pack, once it is assembled, and then the whole packs gets shrink-wrapped. The plates aren't pre-attached to the main board at all.
theRealFury said:Im sure Gary will correct me if im wrong but i think the BMS is built to be used for bulk charging Lipo with a 'dumb' charger such as a PSU / meanwell. Therefore the BMS will not disconnect the battery from the charger. Basically you would have to modify the charger to have a CV of ~4.10v per cell (so around 49.5v for 12S lipo) so that once the pack gets to that voltage the charger will not be able to provide much current, then the shunts on any of the cells that are over 4.10v will open to stop that cell from charging and pass the current onto the other cells. If all cells are above the 4.10v shunt setting then all shunts will be active and burn off any excess current up to a point. Not sure how much current the shunts can handle though, i'd probably guess in the region of 200-300ma?
These boards look really tasty and would love to get one myself but the way i have to mount my lipo will mean there is not enough room to fit this board, my lipo is in a square 2x2 block lengthways. Guess you cant cater for everyone Gary Keep up the good work though
theRealFury said:These boards look really tasty and would love to get one myself but the way i have to mount my lipo will mean there is not enough room to fit this board, my lipo is in a square 2x2 block lengthways. Guess you cant cater for everyone Gary Keep up the good work though
modern_messiah said:I got into the EV game because the motors interested me greatly...I'm on my way to build (or modifying) my own motor and only remembered yesterday that I will need some way to power the thing. Queue me wondering over to the battery thread for the first time and becoming completely overwhelmed in about 5minutes. The battery and power side of EV’s is going to take me longer than the motor side to understand, and that makes me sad :lol:.
Long story short I’m so happy I found this thread because this BMS “pack” is going to save me so much time and trouble. I can’t wait to see the results (and of course price).
Question – the thread title is “12s2p LiPo pack kit including 12-channel BMS "Lite" Board”. This to me implies it’s the full caboodle – batteries plus BMS. Is this correct? No skin off my back either way, I’m just trying to clarify because as I’ve said I’m a little lost at the moment!
I’m also keen to know what charger you would recommend for use with this.
Patience is a virtue…apparently.
stingray17 said:Gary, really excited to see this. Getting started out with LiPo is complicated. The complexity involved in recharging & balancing medium/large packs was enough to discourage me from going LiPo for my first ebike. LiFePO4 weight and C rate might not be the best, but it's easy to recharge a Ping pack without isolating cells, connecting and disconnecting multiple cables, etc.
Nonetheless I really want to try LiPo. So I'm biting the bullet and ordering four of the Zippy 6s-8000 packs. Before too long I will definitely need a 12s2p BMS, so as soon as your kit/PCB is available in a size for the slightly larger 8000mAh packs... sign me up!!
modern_messiah said:Awesome work. So if my understanding is correct the original concept was to have everything in one package, but some heating issues amongst other things have forced you to move the bulk of the circuitry to an external box? Would have been nice to have it in one simple package but whatever needs to be done for the best product makes perfect sense to me!
*cough* can't wait for a price *cough* :wink:
In all seriousness though what I plan to use these for is not even under development yet. So I'm happy to sit and watch. Exciting stuff.
Cheers.
