I'm using a Crystalyte 26" rim and I was having the original 12g spokes breaking here and there usually giving me flat tires in the process. So I got a set of replacement spokes from ebikes.ca which are 14g with washers at the hub. I've replaced the broken 12g spokes with the new 14g spokes so my wheel has a mixture of the two now. The problem now is when I try to tighten the spokes the 14g are pulling right through the rim at the nipple. They didn't do this at first but just yesterday on my ride into work I had a spoke pop out of the rim while riding. I suppose the spoke holes on my rim are meant for the larger nipples of 12g spokes is the problem.
I'm thinking about getting a replacement rim with spoke holes for standard 14g nipples. Would eyelets be preferable for strength so I can get my spokes as tight as possible? Alternatively would I be able to pick up some standard washers from the hardware store to prevent my 14g spokes from pulling through my Crystalyte rim? Anyone know what size washer I would need?
