I actually did laugh out loud reading that, so, LOL.That is a cool electric eel aquarium.
It's a great resource for amateur builders of any hobby. People like me who don't have a CAD or fabrication professional background, it's just so great. I certainly overuse it; probably about 10% of the motorcycle got 3d printed.Kudos on the design and fit. Gives me a strong urge to get into the 3dprint movement.
Acceleration is great, feels the same as it used to, just gets up to a higher top speed. I can and will tune the settings for better acceleration, but personally, I'm not a thrill seeker. The bike is my commuter, errand runner, daily driver, occasional joy rider, energy efficient off-grid transportation. I don't race or burnout.How is the acceleration form the hub motor? Also do you know what your final bike weight is?
The reason I ask is that I've also got a street triple as well so have gotten used to sub 4 second acceleration. One of the reasons I stopped riding my donor bike is that it was just so damn slow and the brakes were terrible. The power model I made shows roughly 6 second for a 0-100kph (0-62mph) with the 8kw hub motor using rubbery torque figures from QSMotor, but every spec they release seems to have different numbers so I'm not confident in what it actually will be. Plus I realise some of this will also be down to the motor controller and battery outputs but I am curious as to how these motors go on 100V in general.Acceleration is great, feels the same as it used to, just gets up to a higher top speed. I can and will tune the settings for better acceleration, but personally, I'm not a thrill seeker. The bike is my commuter, errand runner, daily driver, occasional joy rider, energy efficient off-grid transportation. I don't race or burnout.
Next week I'll take it to my scrapyard and get it weighed.
It can. I could get back to you later when I start testing it out, but yesterday it felt like my 0-100kph was less than 6 seconds for sure. On regular non-boost mode, no tuning, with a 95volt battery. So yeah, I'd go for it. Like you said, it'll be dependent on which controller you're using, and how well you batteries can handle higher amp draw.f it can hit 6 sec 0-100 accel rate then it will be easily usable I feel
Thank you! Good luck on your build. I just worked on mine for a few hours a month, for over a year. I only got busy doing stuff in the past two weeks or so, trying to put all the components together. It happens eventually.Been facing some serious struggles with my build, and seeing your success is a great catalyst. Kudos on things coming together. Looks awesome, and sounds like it purrs that way too.
Thats great to hear. I’ve used a Kelly 8080I which is rated to 500A. My pack uses 74Ah pouch cells which are rated at 2C continuous and 3C burst so it should be fairly well matched to the motor.It can. I could get back to you later when I start testing it out, but yesterday it felt like my 0-100kph was less than 6 seconds for sure. On regular non-boost mode, no tuning, with a 95volt battery. So yeah, I'd go for it. Like you said, it'll be dependent on which controller you're using, and how well you batteries can handle higher amp draw.
Higher voltage battery is the main reason I wanted to do this build, and it seems like it'll pay off.
It's not easy to balance with all that weight, that's for sure! Ive gotten it better than it was, but it does still vibrate a bit.How are you finding the wheel balance? On the one I have the casting is a bit off and has a bit of vibration on the bench.
If you're talking about just the housing and mounting for you batteries, that's it's own issue. I used 3d prints to "help" mount the battery, but the work is really mostly being done by aluminum plate, steel bars, ratchet straps and polycarbonate sheets. And as you point out, if you're having such a bad day that your batteries are on fire, the material in which is housed is going to be the least of your worries.Wonderful precautions with the onboard service equipment. Especially the emergency 12v supply. I'm definitely going to include something like that. It will probably be the only NMC size I'm currently confident enough to include on the LTO system I'm working on.
I just had a post in another forum that leaves some concern for my own build, which I hope to post someday... Anyway, I'm using some prefab PVC 5" square to house prismatic modules. The caution shared with me was PVC is hazardous and caustic when ignited, and the better design choice is ABS or PC. Now, if it gets to the point of ignition, I've got other problems... and on a 2 wheel EV inhalation hazard is lesser, which since it was on a electric car forum, that was likely their stance. Yet, im presently wrestling with with how to mitigate my design...
And I realize by your post that... Most 3D prints like yours are ABS or some non PVC plastic, and (one of the) safe(est) materials for the type of construction were vested in?
Specifically, PA6-GF10 (or 30) is one of the most common used plastics in tools and cases. You don't get all of the same properties when it's extruded out a .4mm nozzle, but you get a lot of the same strength.I had no idea glass reinforced polymer could be 3d printed. I know of it's qualities at minimum by how long my power tools casing have survived.
I was thinking about this. My last bike had an efficiency of 120-140wh/mile. If I were to assume 85 mile range (the low end of my estimation), and my battery has a capacity of 9300wh, that would give the new motorcycle an efficiency of about 110 wh/mile. More efficient. Even though the weight is about the same, I got it weighed yesterday at 368 pounds/167kg. I don't think it's particularly more aerodynamic, is still has a big flat square mass behind the wheel.I've only been on a couple of longer rides, and I've yet to do a proper range test in real world conditions. But if you take my two longer trips that I've made, and assume the range tracks appropriately, I'm looking at a range of 140-160km/85-100m miles. Again, this is awesome for me and meeting the goals of my build.
"This one weird trick that the electric motorcycle industry hates!"Those specs seem really promising. More so than a lot of production bikes I'm reading about. So cool.
Brilliant! This gives me so much motivation to get mine done!I rarely, if ever, take videos, so I apologize about the terrible quality. But here's a couple short clips in case anybody is interested.
