docnjoj said:
View attachment 1Well more bad news. I just opened up my 2 speed and the gears busted again. This is the one I repaired after the same gear broke the first time. It is the sun gear with the central bearing. I have written to Bonnie and we shall see. In the mean time does anyone think I can run this motor with just the high speed gears? I really need 1 motor that works.
otherDoc
I would think you can still use it, as long as you can keep the Sun gear bearing/clutch surface in place and if it can still maintain the same spacing along the shaft still minus any loose or obstructive plastic of course...
The trouble is that I think you'll find it's only the low speed gear that is remaining (more teeth on the outer gear = lower RPM)
After my gear replacement I have gotten another 320km out of it and feels good still, so it is puzzling as to what is causing yours to break so soon, your grease looks good, if the 3 plastic planet gears were touching the hub I am sure you'd hear it (and they'd get damaged, rather than the sun gear)
Did you put in a bushing on each side of the Sun gear when last assembled? I am pretty sure I had one on each side, if that was missing, maybe it'd build up friction too much, or is there anything protruding from the clutches that might have been digging into the plastic, causing it to shatter?
Otherwise as stated, maybe shaft, I can't think of a tricky way to test that, apart from pulling it out and sight it agains something straight, I don't think you can, or want to remove the coils...
knutselmaaster said:
Bonnie assured me that the ones with HAL switch and auto shift will remain available.
This is good news at least
