Green Machine said:
If amberwolf is willing i would like to give him a hub kit as a Christmas present if he agrees to give it a fair review.. .
I was pointed to this thread, presumably for this^^
Do you think this system could handle either of my vehicles in it's "normal range of operation"? (without being a "test to destruction")
And how common is this issue
https://endless-sphere.com/forums/viewtopic.php?f=3&t=58490&start=1150#p1250309
of breaking stuff going backwards? Because I have to back the trike up all the time, while sitting on it (can't usually get off and lift the front wheel...impossible to lift a rear wheel). The bike I also have to back up a lot, and it's not possible for me to lift the front wheel while doing so. So if it can't be rolled backwards reliably without worry...I'd probably break it before even getting it out of the backyard.
Blipping the throttle for it while backing up could get complicated, especially when I am using the other motor in reverse to do that backing up (which I have to do more often than not).
It would need to be able to provide quite a bit of power/torque without destroying the gearing/etc., and do this repeatedly (about a dozen times in 2.5 miles for my work commute), even in summer heat where the system will start out at well over 100F (sometimes up to 140F or more if it's parked in the sun). Keep in mind that just my CrazyBike2 is around 220-250lbs, no rider (just the bike and stuff I carry every day). SB Cruiser trike is much heavier than that, even without me or the dogs.
Since I need acceleration on the order of 4-6 seconds maximum from 0-20MPH on the flats, to avoid conflicts with other road traffic, that's quite a bit of power.
CrazyBike2 takes about 80-90A battery current to do that in ~4seconds, using two DD hubmotors (9C 2806 26" and Crystalyte HSR3548 20") and two 12Fet 40A controllers at WOT, with a 14s1p 20Ah EIG NMC battery.
SB Cruiser has in the past been able to do this in around 6 seconds, but is heavier now and takes longer (still testing to establish new baseline). (2 DD hubs, Crystalyte x5304 20" and 9C 2807 20", 2 12FET 30A controllers).
I could temporarily replace the front 26" wheel of CrazyBike2 with a front version of the Xiongda system, but can't do teh rear (unless it comes in a moped-tough 20" wheel; a typical ebike wheel build will fall apart or break pretty quickly on the rear of CB2; this has happened multiple times).
More practically for my own uses, as I use it much more, I could replace the front 26" wheel of SB Cruiser (presently unpowered) with a front version of the Xiongda system. Again, couldn't do the rear, same reasons as CB2 (and it would have to be a rim that can hold the Shinko tire presently used back there).
Either front wheel replaced would let me test it while riding around, once already acclerated to speed, but other than testing in my local neighborhood I couldn't probably use it to accelrate from a stop (if it could even do it at all).
I don't presently have another bike I can ride with any regularity, as "normal" bikes are too tall for me and I'm too likely to fall over and crash just trying to get on or off the bike.
I could build something to test it with, but I don't know how long that would take, and it would still be significantly heavier than any normal bicycle, placing more strain on the motor/controller system.
So I'm not sure I could perform a review on it that would be useful to other people with normal bikes, other than that if it survives *my* usage, it would almost certainly survive theirs. :lol:
If you're still wanting me to try it out, and are willing to risk it's destruction on the first ride
I'm willing to review it.
Keep in mind that I'd also open everything up and post pics in the review thread, and criticize everything I see just like usual. (including documentation and/or lack thereof)
(oh, and as for me and moderating, with the way people act to each other nowadays, not a chance, unless I'm given a free hand with NO complaints from anyone about who and what gets removed for being spam or OT or against one of the rules, as I would be very strict and harsh about it. I doubt you yourself would like the results, either. But you have no worries since no one would agree to it, and we'd lose a few vendors and their employees out of it).
