Hey, I was primarily referring to the longevity of those packs - basically, the price-value ratio. I find it that I actually don't need that much discharge, with an all-time maximum of 53 Amps being pulled from the MAC. So, if I can save some weight on the C rating, I think it should be okay. Plus, with the possibility of a mid-drive (like GNG or whatever), it may be that it'll be pulling even less amps for the same performance.
But I guess the weight itself isn't as big of an issue as its distribution - right now the battery is in my rear bag. Having a motor in the rear wheel, the battery pack on the rear rack, plus being 240 lbs as it is, puts a considerable stress on the rear of the bike. Right now if I lift the front of the bike, the weight misbalance is very noticeable, allowing me to effortlessly rotate the entire bike 360 degrees with one hand - meaning it's the rear that pushes this much weight into the ground. If I could find a decent solid pouch holder (I've even tried dog bags, nope) - maybe bent aluminum or some other sturdy metal, I can see securing it on the top tube of my Paratrooper, balancing out the forces. Plus, with a mid-drive like GNG, even less stress is put on any particular end of the bike. I could look into something that another member posted recently with his GNG on Lipos and putting them on rain gutters (or whatever that was).
