I got my 304 steel wire, so I got around to make a new spring:
I broke the mandrel in the first photo, so I moved to steel ones. Got this one only on my third or fourth try:
I couldn't wait and decided to do at least a brief test of a full system. Needless to say, that was almost a complete failure. I managed to push _some_ fluid out, but the sleeve being so loose meant when the fluid was added it almost floated freely in the cylinder housing. Even worse, it rotated so that the holes didn't line up with the holes in the cylinder.
On the upside, nothing broke or dissolved from the fluid, i managed to get a couple of bubbles from the right hole, and the spring seemed to work way better with a piston lubricated by the fluid. Unfortunately the piston goes so far into the housing that all the springs i made were invariably compressed past their plastic deformation point.
I attribute this to a couple of potential reasons:
1) the original spring being conical and able to fold onto itself better
2) the original spring made better (with more even windings and no flat sections at either end)
3) my spring not being annealed/de-stressed or otherwise made of poor quality metal (the wire came from aliexpress, remember)
The main issue remains the sleeve, though, and I'm a bit torn whether to continue this experiment. I am not sure if I can get it to work reliably, on the other hand i have a couple issues that i could immediately address and see if anything improves - mainly the sleeve being too loose. At the same time, I have a 9.5mm (I guess that's 9mm nominal piston diameter?) pump coming in the mail, probably next week. If that turns out okay, there will be zero reason for me trying to convert mine to 8mm.
Alternatively, I keep thinking about other ways to reduce the fluid flow. A larger rear caliper is an obvious solution, the problem is the original honda one comes with a carrier that also acts as a wheel spacer, and the brake is an integral part of it. Anything that would fit or replace it would likely be very expensive.
I don't get it. How do people normally do LHRB that actually works?
