"250W" aluminum engraved LABELS for BBS02
NightRider
I came up with a good solution to increase my "stealth" here in Europe, where one is limited to 250 watts. (The law actually stipulates that the wattage can go significantly higher while one is going up-hill or accelerating, which is quite a loophole. This means that it is theoretically possible for the BBS02 to be road legal, as long as the top speed is limited to 25 kmh, plus or minus ten percent, so 27.5 kmh, and as long at the motor is not pulling more than 250W at this cruising speed. You must also have the thumb-throttle disconnected.)
Here is where you can order these aluminum labels. Both of these are exactly the right size to cover the underlying text that is stamped on the motor from the factory:
http://www.ebay.com/itm/351371846169
http://www.ebay.com/itm/361271373764
You'll need to give the guy specific instructions as to the text that you want engraved on them. The black"250W" label has rounded corners, which you would need to specify. They came with double-sided tape, which you can request free of charge.
