Recumbent Bicycle Source
I'm trying to find out if it's possible to find ANY Rear Drive hub motor that will fit a 130mm drop out.
It's my understanding that the rear drop outs for ALL the hubs (at least the ones I've seen) are for 135mm.
I don't mind having a custom wheel built on a hub if I can find one for 130mm spacing. I can not bend the frame on this bike.
I also understand there are few or perhaps even ZERO options available for a 9 speed cassette even on 135mm hubs.
The alternative for me would be to run a front wheel... but that would require a new fork, which is a problem in itself due to a headset shock. Thus if I were to replace the fork I'd need to match the Geometry of the existing shock. I understand Canondale makes their own Headset Shock, but I have not found any others. I'm not concerned about the shock but the 2-3" distance between the top of the shock and the bottom of the headset is a problem. Without this space there are chain line issues with the bike I want to convert.
Ideas to pursue?
On a side note I don't see to many people here running electric conversions on recumbent bikes.
Has anyone here put one on a Challenge, or Optima or HP Velotechnic?
Ideas to pursue?
