JMK1000
- Joined
- Mar 1, 2020
- Messages
- 17
Hi Group,
Thank you for accepting me to the group. I have a question (probably layman question) about the battery for a scooter I have.
It is a scooter with a 250W brushless hub motor in a front wheel and a 5.8Ah 37v battery in configuration 10s2p.
Since the distance on single charge is really not very impressive (about 5 miles), I want to add an external battery with a switch, allowing me to switch to an external battery when the main one is exhausted (or rather start with the external and when it's gone switch to the internal.
I would like to use, as an external, a battery with more capacity, so I thought about 10s4p. As I understand, comparing with the 10s2p, the 4p has less voltage drop, with the same system attached.
My question is about the dangers: it can draw twice as much amperage if the attached system requires that, so is it risky to attach it to the system which originally had 10s2p? The battery was limiting the output. Or it should not matter. My scooter is Megawheels S5, but this is not important since there are plenty of scooters in that configuration.
I would appreciate if anybody could address such a trivial question of a 'newby'. Thanks. Jack
