Do you have a pic of your 43V controller that you can post (with the label)?Hi
I'm trying to find a battery. My battery is 43v, which seem impossible to find.
However 48v batteries are everywhere.
So my question is what do I n3ed to step down, a 48v battery to be able to use it directly with my 43v bike?
Thanks
Well funny that you should mention that. As you can see from the label, it says 36v motor!How do you know it's a "43 volt battery". 43v is about full charge for a (nominal) 36v lithium ion battery.
Well i do have 2 36v batteries from previous ebikes.What kind of bike do you have that's so persnickety about voltage? Almost every bike I've built for myself or others will play just fine with anything between 30 and 60 actual volts. Are you dependent on a cartoon diagram of a battery on your display? If so, a weird battery isn't what you need.
