solarbbq2003
- Joined
- Apr 7, 2007
- Messages
- 500
just finished experimenting with hall sensors to change 120degree motor to 60 degree and vice versa. very useful for matching controllers if controller is not easily adjustable between 60/120 degrees
for 60 degree spacing all three hall sensors face in same direction,
for 120 degree the middle hall sensor is facing opposite way.......that simple.
so flipping middle hall sensors around 180degrees ( upside down or back to front however you like to look at it ) is all that needs to be done.
Basically the writing on the hall sensors faces the magnets for 60 degree, the middle sensors side with writing on it faces away from magnets for 120 degrees.
By the way does anyone know how to convert a crystaltye controller from 120degrees ( which is what they run as ) to 60degrees? would mean could be used on alot of different motor types without having to take motor apart.
I know some controllers is just a matter of changing one resistor value to convert, hoping someone might know the secret for crystalyte controllers.
