bobale said:How much you've added to shunt thickness to cause FET(s) to blow?
bobale said:Well, as my HuaTong pulled about 34A unmodded, I guess that 50A from it is really pushing it.
Finzent said:Square root 2 is a good divider almost everywhere in electrics, so if the FET's r capable of 75A it calculates about 53A.
mauimart, you're running a rc setup right? I have no experience with those motors but will they handle >40amps? Also you must be seeing super high phase current. What kind of rpm are you seeing before you loose lock?mauimart said:. I am in the process of scoping the phase current to get an idea of what the FETs are experiencing. I will post once I get some meaningful results.
cohberg said:mauimart, you're running a rc setup right? I have no experience with those motors but will they handle >40amps? Also you must be seeing super high phase current. What kind of rpm are you seeing before you loose lock?
stewrobb said:Okay, so I just received the Greentime controller, and I must say am very impressed (although it took like 40 days). The jittery behaviour I felt from starts and at certain throttle ranges with the hua tong are non existant with this controller, very deliberate. The current seems a lot higher, but I don't have a wattmeter to give an exact figure, they say 45 or 50A, depending where you look, I suspect it's closer to the 50 range.
What was extremely interesting to me is the connections used for regen braking, If you look at my earlier post, with my Hua Tong, I used X and got reverse current, albeit for a short moment until the phase wires were shorted out, which told me that it was capable of regen, although I couldn't figure it out. On this Greentime, the regen is activated by connecting DS and X. I am super busy with midterms and such, so I won't have the chance to try this out on my Hua Tong (x may have to be connected to something other than DS), but if any of you folks want regen(very redundant), my suggestion would be to try connecting x to something other than GND, I would bet money that this is the ticket. It is activated when a brake signal is present.
https://picasaweb.google.com/104673449835553898679/Dump?authuser=0&feat=directlink
Good luck, hopefully someone else will carry on the regen flame and finish the race for everyone still using a Hua Tong!
It makes no difference if you use a pot or a fixed resistor. The electrons don't know the difference. The danger is if you set the pot resistance wrong. Set the pot to exactly the resistance you need for the LVC you want. Then glue or wire the pot shaft to lock it.jk1 said:Will this Huatong LVC adjustment with 5k pot be danagerous o blow up the controller , same as the Infineion controller if the LVC is set too low ?
so it is true if the pot or resistor is set incorrectly we can blow up the controller ?
so then i guess its important that the actualu LVC set point be tested after the new resistance is added to make sure it does cut out at some low voltage , i.e that that fucntion still works
Can you point me to that document?DSX said:In the infineon blurb it goes into the detail of what causes the controller to fail.
Do you have oldest style HuaTong, or newer ones? I can't remember.DSX said:In my case regen does not work at my battery voltage (too low) but the cruise function works.
On the model in subject, grounding the X (not small x) pad initiates regen. I ran it through the ebrakes, but you can do it any way that shorts it to ground. It won't work at higher than stock voltages without modifying the circuit. Don't recall the exact voltage where it stops working, but it's somewhere around 78V or higher.bobale said:Thanks for the doc . I'm now not sure which Hua Tong I have as I'm not near it and can't check, but how did you enabled regen in the end?
cohberg said:To those following the new controller, I have pictures but not much more. I was wrong about it just populating the unused pads in the 2nd generation board. This new board is a complete redesign and now there are a lot of new pads to decode.
Difference noted thus far are: C-D3.1 board, different IC, new 4.3V power supply for the throttle (for safer 24s operation), a 15V supply, 63V supply, Functions 1-8, SL, DS, XS.)
I haven't tested any of them, just modded it for 60A and slapped it on my bike. And no, I haven't tested if there is regen, but even if there was it wouldn't help the 2nd generation guys because the chipset is different =/
I think for brevity i'm just going to upload the entire photoset to picasa and if you guys are interested you can do through it there.
Gordo said:It is impossible to know what you will get when you purchase this controller. We all thought we were getting the same controller because it has a part number #OT100. This part number means NOTHING Everyone ordered and received a OT100. Some just happen to be different than the first batch. For $3X.00 landed at your door, who cares? The thing works and as you can see, from those who have gone before you, shuttles a basket load of electrons from your battery to your motor without burning up.
