Hummm.. I really think i can't lcomplete that subject like that without giving an explanation :|
This afternoon, i friend of myne come to see me at my house. After few minutes discussing, I decides to show to him what my new E-bike look's like.
I disconnected my battery from my charger see below:
This charger push the voltage to 90V total in my battery pack.. I charge them for 2 hours to equalize them and drop the voltage to 14.4 for the rest of time.
What happened (maybe!..) is that forgot to leave the battery free of cahrging for few minuts to allow the voltage to stabilyze and decrease to around 82-83V nominal.
I immediatly took my battery pack and plugged it on the controller
.. I dont remember if the switch was on or off on it... but it happenned in the past without problem.
Immediatly when I plugged the 50A Anderson connector it makes a spark.. a bit louder than normally.. I assume that the caps inside charge faster ands does a peak current... BUT.. that was louder this time...
The Drainbrain become powered and it was ready to operate... ha haaa.. i decided to show to my friend what look like the torque the motor have by just twisting the throttle to the mid position few time and to see the bike moving quickly and pushing with my front weel my toolcase on the ground....
That occured but only for 2 second... and after that my drainbrain shoted down and My fuse (a 40A 32V :... 32Volt :lol:... burned.... eeee... VAPORISED
and leaved a black powder inside the fuse cover(probably the short flame or.. PLASMA! generated)
Well.. .I tried to replace my fuse by another.... and the same thing happened BUT this time i also heard a clic in the controller...
WTF!!.. I immediatly think about the Fets... those ?%?%?$ kind of transistor.. (you just watch them and they blow!!!)...
I smells no smoke from the controller because of the silicone that i corectly put on all the joins.
And finally.........., i'm here... without any possibility of still having fun with my new ebike....
What i think...
-for sure, that was not a good ides to immediatly plug the battery on the controller with a high voltage and avoiding those to stabilyze to their nominal voltage! maybe the controller is a 72V with 100V fets, but probably a little bit borderline taking acount od the pwn that oscillate and generate high volts spike when "3 phasing" and modulating the pwm..
-My second point is that the spark that the anderson connector do each time I plug the battery is certainly bad, because generating spike and hf-hv pulse in some inductive circuit like a hub motor in seri with fets... maybe some caps are too "slow" and leave passing thru the circuit this hv..
-My last point is that i seen that my drain brain was factory preset to 50A max and i decided to leave it to that value....
... I can't stop repeting to me : "why i did not set it to the 35A nominal current it is supposed to have!!"... i'm stupid for that too!.. ha ha... no.. i preferes to have fun with acceleration and to post some recorded A peak like 42A....
I regrett that!.. why i did that!!!
is it me.... is it the responsability to the seller of the controller to forget seting it to 35A limit... (it's V2 of the drainbrain.. no shunt to modify... it's too easy to make your own adjustment and puting it up to 99A !!
I repeat.. you could have the bad luck i had!... 35A.. i really think it should stay 35A no more... :x
I've carefully reed some post about controller repair/mod here. they are pretty interesting and i better understant how this controller operate.
I seen you Fechter that have an excelent understanding about this controller and 29A and Xyster i think.
For sure, i want to repair it!!!
and i want to make it bulledproof!
Now i would appreciate any help from you guys.. .and as i can... i will give you my best for any help you need that i have a great hability in.
Doc
