august23
- Joined
- Feb 15, 2012
- Messages
- 79
I am trying to get my head around what is happening to my e-riding experience when using 2 different chargers for 2 different battery packs. one is with a slow 1.2amp charger. the other is a 2.0amp charger (both 24v). Obviously the high the amps, the faster the charge. But what is really happening? I was once told that I should stick to one type of charger per set of batteries to avoid shortening the life cycles of the battery. He also said "high amps in, high amps out and short charge time equals short discharge time". Can anyone confirm and/or elaborate on this?
another question about batteries: if I have 4 12v SLAs running in series to make 48v, which batteries are drained first? the ones closer to + ? or are they equally drained?
another question: say I have a 48v sla pack. if I charge it with one 48v 1.5amp charger, would it take the same amount of time to charge them as 2 separate 24v packs w/2 24v 1.5amp chargers?
another question: when shopping around for 48v battery chargers, I found some ebay listings that specified the amphours of the battery it should goto. like "48v 20ah battery charger" but it didn't specify the amps. would this charger work on 4 12v 10ah SLA batteries? if not...why?
(http://www.ebay.com/itm/48V-20Ah-battery-Charger-Scooter-bike-For-Razor-/350544097071?pt=LH_DefaultDomain_0&hash=item519e0e6f2f#ht_1428wt_1397)
And yet another! Overcharging: I have a Cycle Analyst and a volt meter that are both reading 39v on a fully charged 36v system (3x12v 10ah). Is this typical? is it bad? please elaborate.
Thanx!
Augie
Thanx!
Augie
