Hey guys,
I absolutly need to advice you about a technical problem that may occur if they are not current limited!
Ex:
Your LiFe cell is completly Empty and present a floating voltage of 2.8V(no load) (2.5V under normal load)
When you will apply current on it to recharge it let say 5A, the voltage will keep under 3V for a couple of second
in this case, the voltage difference between your dc-dc (3.6V) and the cell will start to around 0.8V... 0.6V and will stabilyze to around 3.3V during 80% of the cahrging process.
What is important to unserstant is:
AS THE VOLTAGE OF THE CELL HAVE NOT REACH THE VOLTAGE OF THE OUTPUT OF THE DC-DC THE CURRENT WILL BE MAX !!!
The DC-DC used with no current limit but that is just CV controlled will put the max current availlable.. and for exemple, the BXB150 can put 39A !! that is around 7A at input with 36V and around 5A with 48V input.
YOU NEED TO PUT A RESISTOR BETWEEN THE DC_DC AND THE CELL to limit the current.
the problem that can occur is that if you use many DC-DC to charge 12s.. and the cells are empty or not full, the voltage difference between the dc-dc and the cell will make it to control the CV to stabilyse to 3.6V (preseted by the resistor) and to do that it will put ALL current availlable if it is not limited. Then you could need to supply the 12 DC-DC with 5A each at 48V that is 60A... and using only 2 or 3 500W 48V power supply will never be able to handle that and their voltage will drop too low and will SHUT UP THE DC_DC because their input will go below the 32.4V low limit.
Without limiting the current, a single cell A123 would be recharged to 39A.. AND THAT IS BAD
... You need to limit the current! oir buy the brands new Vicor DC DC 150W that have a I limit but they are $$$... the BXB150 was 10$ so finding a way to limit their output current seems more adequate.
You need to understand that as far as the cell voltage and the dc dc are not the same, the current will be max. If you add a serie resistor,, that will be ok... and solve this problem.. but two disadvantages will occur: first, you will dissipate and loose energy in heat, and finally, you will not be able to preserve the ideal CC-CV mode because that the current will decrease as the cell voltage increase (why? .. just because the less the voltage difference between the cell and the dc-dc is, the less the current will be high thru the resistor.... and the cell will recharge slower as his voltage increase...
CC-CV is the most efficient method for getting a short charging time. With a resistor in serie, the CC charging time can't exist.. that increase the charge time.
I'M working on a current limiter that affect the V trim input to control current.. be patient, i will post something about my final desing soon..
Doc
to avoit drawing full power on the dc-dc with
